just curious if this would work or not
engine is 440, fuel tank is new, using original sending unit (not 440, no return provision)
however, there are the 4 vent tubes at the upper drivers side of the tank that go into the rear wheel well, then one comes back out, but goes nowhere since the car's been modified.
now for my idea that may or may not be a good one: run a chevy style fuel filter with the vapor return nipple on it, run a line back to the gas tank and have it connected to one of those vent tubes and then cap the others off - i'd guess i would need a vented cap if this is possible to do.
just looking for ideas
