moving master cyl. to fire wall? #756707
07/24/10 01:04 PM
07/24/10 01:04 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i want to move the mastercyl. to the fire wall on my 47 desoto. has anyone done this using parts from a donor car/truck? what make/model should i look for? if possible i would like to keep it mopar.
Re: moving master cyl. to fire wall? [Re: 65rbdodge] #756708
07/25/10 12:10 AM
07/25/10 12:10 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Whatever you do, don't use the small diameter (8" or less) boosters, they are pretty useless and a waste of money.
If you have the room, I've had real good luck with the booster and master from a mid 80s 5th Ave. Gene
Re: moving master cyl. to fire wall? [Re: poorboy] #756709
07/27/10 01:44 PM
07/27/10 01:44 PM
n.e. pa.
n.e. pa.
ok, i`m not going with power brakes, IMO the booster is ugly and doesnt fit in with an old car and power brakes are not necessary, manual brakes stop just fine. i took the brake and clutch pedal out of an 80`s dodge truck today. i think i can get it to work in my car, i just need to do some cutting and welding.
Re: moving master cyl. to fire wall? [Re: 65rbdodge] #756710
07/28/10 08:21 AM
07/28/10 08:21 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
did you take the complete pedal assembly and all the bracketry,,,that way when you mount it you can locate the master cylinder mounting position,,and have all the proper gemoatry,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: moving master cyl. to fire wall? [Re: poorboy] #756711
07/28/10 01:04 PM
07/28/10 01:04 PM
PA
W
Waynes48 Offline
Waynes48  Offline
W
PA
I got a MC/pedal assembly from a mid-70's Valiant that had manual disc/drum brakes for my 48 Plymouth. Not completely done with the installation, but so far, all looks good. Needed to cut up the pedal assembly a bit, and need to fab some bracing, etc. The Plymouth is being comverted to front discs, with 10" Roadrunner drums in the rear.
Re: moving master cyl. to fire wall? [Re: Waynes48] #756712
07/29/10 02:10 PM
07/29/10 02:10 PM
n.e. pa.
n.e. pa.
i didnt get the braketry, it would be very hard to do with hand tools as its spot welded in place. maybe i can find someone parting out a truck that can cut it out for me.
Re: moving master cyl. to fire wall? [Re: 65rbdodge] #756713
07/29/10 10:22 PM
07/29/10 10:22 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Brake pedal brackets for a Dakota (at least 1st gen 87-90) are bolted to the firewall inside the cab. Gene
Re: moving master cyl. to fire wall? [Re: poorboy] #756714
08/10/10 03:51 PM
08/10/10 03:51 PM
n.e. pa.
n.e. pa.
i found a set up out of a 91 ram 50, it looks like it will work pretty good, i got the break/clutch pedal/slave cyl. for $10.60. the 2 pedals are seperate units the clutch has the return spring built in.
