340 Victor vs M-1 #756677
07/24/10 12:52 PM
07/24/10 12:52 PM
Amarillo, Texas
red70duster Offline OP
Amarillo, Texas
Theres a Victor 340 available around here for $ 125.00. I am currently running the M-1 single plane. Would it be worth it to swap to the Victor? Car has a 360 stroked to 410, solid cam, 950 carb, edlebrock heads, 4500 stall convertor, and 456 rear. Currently runs 10.90 in good air. Is it worth the hassle to swap?
Re: 340 Victor vs M-1 [Re: red70duster] #756678
07/24/10 01:57 PM
07/24/10 01:57 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
For a $125.00 bucks,its worth the try!!!
Re: 340 Victor vs M-1 [Re: red70duster] #756679
07/24/10 02:07 PM
07/24/10 02:07 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What rpm do you get max with the M1?
Re: 340 Victor vs M-1 [Re: red70duster] #756680
07/24/10 02:19 PM
07/24/10 02:19 PM
AndyF Offline
AndyF  Offline
I don't know if it is worth the hassle or not but the Victor is a nice intake. Double check the thermostat area as well as the water fittings before you get too far. The M1 used a weird design up front on some manifolds. I'm also not a big fan of the Thermoquad carb pad that the Mopar engineers stuck on most of the M1 intakes.
Re: 340 Victor vs M-1 [Re: red70duster] #756681
07/24/10 02:57 PM
07/24/10 02:57 PM
Amarillo, Texas
Amarillo, Texas
I shift at 6600 and go thru the traps anywhere from 6600 to 6800 depending on what tire I am running.
Re: 340 Victor vs M-1 [Re: red70duster] #756682
07/24/10 02:58 PM
07/24/10 02:58 PM
Any pics of your car????
Re: 340 Victor vs M-1 [Re: red70duster] #756683
07/24/10 05:13 PM
07/24/10 05:13 PM
Amarillo, Texas
Amarillo, Texas
Re: 340 Victor vs M-1 [Re: red70duster] #756684
07/25/10 11:20 PM
07/25/10 11:20 PM
NICE RIDE!!!!!! Whats it weigh??
