727 Trans Leak HELP! #755902
07/23/10 01:51 PM
07/23/10 01:51 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Last fall I pulled my eng/trans out of my 89 D150 because the front trans seal was leaking.I cleaned the engine and replaced the seals and gaskets and painted the eng. I replaced all external seals and gaskets in the trans and everything looked good.When I ran it down the road the trans still leaked out of the inpection cover. I pulled the trans AGAIN and carried it to a local trans shop.He inspected it and replaced ALL seals and gaskets in the front of the trans and I reinstalled it. I can drive it for 15 minutes and park it on concrete and in 1 hour there will be a spot of fluid 8 inches in diameter. In other words it still LEAKS like Hell.Any suggestions? If it did not run so well I would set on fire.Trans Guys I need your help.Where can it be leaking so much?
Re: 727 Trans Leak HELP! [Re: 68GTS383] #755903
07/23/10 02:00 PM
07/23/10 02:00 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
check the dip stick tube seal (O-ring) where it goes into the trans case.....don't ask me how I know
MikeR
Re: 727 Trans Leak HELP! [Re: A12] #755904
07/23/10 02:02 PM
07/23/10 02:02 PM
Andrewh Offline
Andrewh  Offline
also the selector shaft seal.
most people are too lazy to replace that one.
Re: 727 Trans Leak HELP! [Re: Andrewh] #755905
07/23/10 02:58 PM
07/23/10 02:58 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
I replaced ALL external gaskets and seals on the trans. The fluid is coming out of the inspection cover at the front of the trans!
Re: 727 Trans Leak HELP! [Re: 68GTS383] #755906
07/23/10 03:51 PM
07/23/10 03:51 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Most cuases of multiple seal failures are a result of a worn bushing in the pump.
It could also be a cracked conv snout but my $$$$ is on the bushing causing the seal to wear prematurly.
Re: 727 Trans Leak HELP! [Re: WILD BILL] #755907
07/23/10 04:48 PM
07/23/10 04:48 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
I forgot to mention,the guy at the trans shop pulled the pump and replaced the bushing,gasket and front seal, He also checked for cracks. There is a small pipe plug below the pump housing,I pulled it and installed teflon tape on the threads.The torque converter neck was not grooved or pitted.I hate to pull it again but it runs and drives really good.I made a 425 round trip pulling a 70 RR on a trailer with no problems.Is there anything else that can leak on the front of the trans?
Re: 727 Trans Leak HELP! [Re: 68GTS383] #755908
07/23/10 05:28 PM
07/23/10 05:28 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
There is a vent in the pump housing. It could be puking out for some reason.
Re: 727 Trans Leak HELP! [Re: 469runner] #755909
07/23/10 05:35 PM
07/23/10 05:35 PM
nc
trex Offline
trex  Offline
nc
had the same problem turned out to be a crack around the convertor
