Re: drive shaft loop ???
[Re: Moparnut426]
#754690
07/21/10 08:26 PM
07/21/10 08:26 PM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
The loop has to be within 6 inches of the front u-joint.
Dennis Jokela
I started out with nothing,and I still have most of it.
[Re: DennisJ]
#754692
07/21/10 08:37 PM
07/21/10 08:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Dennis Jokela
Yep... within 6" of the joint ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Moparnut426]
#754694
07/21/10 08:49 PM
07/21/10 08:49 PM
MR_P_BODY
Well, it looks like I have to move it huh...
Kasey
And that rear hole on the top... I would use it to bolt it to the floor(with spacers if needed to center it... I dont like the back out there floating in space if the shaft come off) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Moparnut426]
#754696
07/21/10 09:00 PM
07/21/10 09:00 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Per NHRA ......... must be located within 6 " of front U joint. I used the old school 26.00 safety loop.......bolted through the floor and with a little heat and beat , it is a very snug fit. Now that I am switching to a 904 , I may have to move mine , but then , I could also shove the motor back a bit since I am switching to motor plates too. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Moparnut426]
#754698
07/22/10 10:03 PM
07/22/10 10:03 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
At least you put one in there. That is something that would cause a lot of newbies trouble at the tech stand. Back when we had tech stands. Now days at a lot of tracks, if you have the $ for the entry fee, you pass tech. Glad to see you care enough to do it right. ![](/ubbthreads/images/graemlins/thumbs.gif) Brian Dunnigan
