Re: Weird starting problem 68 RR
[Re: Cudajon]
#753252
07/21/10 09:12 AM
07/21/10 09:12 AM
Posts: 236 Maryland
cudaboone
Maryland
VERY INTERESTING: My 528 hemi has started doing the same thing. Cranks over and when you let off the key it will fire. Sometimes start right up when you let off the key. I have the summit street strip digital ignition and msd pro billet distributor. It worked fine until recently. Also, my battery is trunk mounted.
[Re: ademon]
#753253
07/21/10 01:46 PM
07/21/10 01:46 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Double check the gap of the reluctor inside the distributor.. Use a brass feeler guage should be 0.006-0.008". Since this is a passive part if the gap is too wide the ECU will not fire the coil. Just my $0.00...
[Re: ademon]
#753258
07/22/10 01:06 AM
07/22/10 01:06 AM
RapidRobert
Go back to basics: right from the gitgo I'd have someone turn the key as you have the coil to dist wire in hand held 1/4" from metal to confirm/deny that there is no spark then start checking voltages and subsystems to find the open starting w the pickup as Sinitro said. EDIT reread your post and yes your voltage drops are way too much
