Is this consistent? #752778
07/19/10 06:47 PM
07/19/10 06:47 PM
Peoples republic of clackamas ...
atoetly Offline OP
atoetly  Offline OP
Or should I work on it? Saturday at the mopar race in woodburn I made two runs in the right lane and three runs in the left.
Right lane
Pass #1-----------------Pass#2
60' 1.308 -------------60' 1.308
330 3.887--------------330 3.889
1/8 6.096--------------1/8 6.096
1000' 8.034------------1000' 8.031
1/4 9.691---------------1/4 9.692
Left lane
Pass #1---------- Pass #2-------------Pass#3
60' 1.313--------60' 1.296-----------60' 1.310
330 3.891--------330 3.870-----------330 3.886
1/8 6.095--------1/8 6.082-----------1/8 6.088
1000' 8.026------1000' 8.023---------1000' 8.021
1/4 9.678--------1/4 9.682-----------1/4 9.678
Re: Is this consistent? [Re: atoetly] #752779
07/19/10 07:04 PM
07/19/10 07:04 PM
sg66mopar Offline
sg66mopar  Offline
Dude, if you can't do better than that I want YOU in first round
Most of us would kill for those numbers! Wish I could've been there to see it.
Re: Is this consistent? [Re: atoetly] #752780
07/19/10 07:08 PM
07/19/10 07:08 PM
Lehigh Acres, Florida
rickstershemi Offline
Right lane
Left lane
That's just plain mean .....nice numbers, if you can't work with that, you need to find another line of work....
Rickster
Re: Is this consistent? [Re: atoetly] #752781
07/19/10 07:09 PM
07/19/10 07:09 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
is this a trick question?
Re: Is this consistent? [Re: dustergirl340] #752782
07/19/10 07:18 PM
07/19/10 07:18 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
now post reaction times and we'll see if you need work, car looked good each time i saw it, leaves hard
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Is this consistent? [Re: atoetly] #752783
07/19/10 07:26 PM
07/19/10 07:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Right lane
Left lane
Over the weekend I put 5 10.01x runs in a row...
with close to 30 degree temp swing..... you dont
have to worry
Re: Is this consistent? [Re: atoetly] #752784
07/19/10 07:27 PM
07/19/10 07:27 PM
Locomotion Offline
Locomotion  Offline
The only "work" you need to do is to keep track of anything that may be a factor in your ET's & MPH.
You didn't say during what times of the day and the overall order of the runs you made. (i.e.: L, L, R, L, R.)
"Usually" early morning or later evening will provide best ET's with slower times in the middle of the day. Wind, weather fronts, humidity, temperature, jetting, water temps, shift points, etc., etc., etc. are all factors. You need to know why you were consistent that day and know how all the factors may affect that consistency in the future so you can predict and dial-in to compensate. Conditions may not be the same next time. If you are doing things consistently in the driver's seat, then it's that much less you have to be concerned about.
I have an Autometer playback tach which has been VERY helpful in keeping track of when I do things right or wrong and consistently or not.
MPH can be a good indicator of the affect a breeze/wind and its direction can have between runs.
Re: Is this consistent? [Re: Stroker Scamp] #752785
07/19/10 07:34 PM
07/19/10 07:34 PM
atoetly Offline OP
atoetly  Offline OP
Reaction times are as follows
Pass #1 .064 I knew I was way late as I had the delay box set up to go red if I was where I should have let the button go
Pass #2 -024 No delay box change and this is what I expected
Pass #3 -.005 Made change to delay box
Pass #4 .027 added to much time
Pass #5 .027 Left box alone should have removed some time but I hate to second guess that darn thing.
I also have much better reaction times in the right lane as I don't have to look across the hoodscoop If I where bottom bulb racing my hood scoop in the left lane would be a real problem.
Re: Is this consistent? [Re: atoetly] #752786
07/19/10 11:09 PM
07/19/10 11:09 PM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
I ran 5 11.60's at martin over the weekend.I say it was because I was pitted next to Mr P-body and it rubbed off.
Re: Is this consistent? [Re: pro6pakRR] #752787
07/19/10 11:17 PM
07/19/10 11:17 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Chiefie,that there's funny!...HaHaHa!!!
Re: Is this consistent? [Re: Labratt] #752788
07/19/10 11:29 PM
07/19/10 11:29 PM
PA
moparacer Offline
moparacer  Offline
PA
Those are some great passes!
Sometimes you get on a roll and it just happens like that.
I did something similar when I won on the 4th of July.
Ran 6 9.74's on a 9.74 dial, was killing the tree and cutting the stripe to .00_
I wish it was like that every week we could quit our day jobs lol.
P.S. I agree 100 percent on the playback tach as I footbrake and shift the car myself and the 1 time my car didn't run a 74 (went a high 75) I replayed my run and realized I was short on the shift.
