Re: Wore one spot in my band new rear main seal????
[Re: 10.90 Racer]
#752675
07/19/10 05:13 PM
07/19/10 05:13 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
what did or could have touched it.
converter balloning ? too much end play in the crank ? ?
home of the Sox and Martin Hemi Duster
[Re: 10.90 Racer]
#752676
07/19/10 05:24 PM
07/19/10 05:24 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Well I've been specializing in oil seals for 20 years so lets see if we can figure out what the heck went on. Do you have a pic of the seal? Was the seal in the block or main cap side? Also was the seal installed in an "offset " position? Was the block line bored? If the crank is out of the block, install the main cap and measure the seal groove to confirm concentricity. Should be the same diameter vertical as horizontal. Greg
[Re: B G Racing]
#752678
07/19/10 05:38 PM
07/19/10 05:38 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Like Bob says. Sometimes people put silicone behind the seal, and I have also seen where the cap rail is dented in, and cause weird seal wear. You will ( or should) find something that casued it.
RIP Monte Smith
[Re: 10.90 Racer]
#752680
07/19/10 08:21 PM
07/19/10 08:21 PM
roadhazard
Akron, Ohio U.S.A.
PM sent Measure across the seal groove in the block and the cap, (dial calipers will get you close enough)then compare measurements to verify they are at least the same width across the parting line. Also was this motor together before and if so all the same components except the rear seal?
[Re: 10.90 Racer]
#752683
07/20/10 09:30 AM
07/20/10 09:30 AM
roadhazard
Akron, Ohio U.S.A.
Pic's too blurry Back up and post a clear pic of the seal lip where the crank makes contact. I need to see the helix lines. So this is a different block but the same crank?
[Re: roadhazard]
#752684
07/20/10 10:16 AM
07/20/10 10:16 AM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
I'll try for another picture. Same crank different block. BTW there is no damage at the parting line. The damage starts about 1/4 in below the parting line.
Is the a possibility there was a just a flaw in the seal??
