valve covers for w2 heads #751640
07/18/10 07:24 PM
07/18/10 07:24 PM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
Building my first w2 motor I realized my old m/t valve covers wont fit. They hit the rockers bad. Using harland sharpe rockers. What valve covers can I use that will clear rockers? If you have a set pm me price. Thanks
Re: valve covers for w2 heads [Re: w2dak394] #751641
07/18/10 07:27 PM
07/18/10 07:27 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im running the mopar performance reverse lip vc, and Im running the sharps also.
They arent cheap!!
Kasey
Re: valve covers for w2 heads [Re: Moparnut426] #751642
07/18/10 07:29 PM
07/18/10 07:29 PM
ohio
all spooled up Offline
ohio
on my w2s i have fab alm sheet metals and h sharps olso
Re: valve covers for w2 heads [Re: all spooled up] #751643
07/18/10 07:33 PM
07/18/10 07:33 PM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
Will the fab. alm. covers from kmj clear?
Re: valve covers for w2 heads [Re: w2dak394] #751644
07/18/10 07:36 PM
07/18/10 07:36 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
using MP Cast aluminum with crane rockers.
Tony
70 AARCuda Vitamin C
Re: valve covers for w2 heads [Re: 70AARcuda] #751645
07/18/10 07:51 PM
07/18/10 07:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Batten W2 heads, Sharp rockers, MP cast "regular" covers. Had to notch them for the intake runners (Holley Strip Dominator).
Thick cork gaskets.
Re: valve covers for w2 heads [Re: w2dak394] #751646
07/18/10 08:49 PM
07/18/10 08:49 PM
ohio
ohio
donot know the brand of mine but thers tons of room
Re: valve covers for w2 heads [Re: all spooled up] #751647
07/18/10 09:57 PM
07/18/10 09:57 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
MP cast alum w/sharps and no problem!!
Re: valve covers for w2 heads [Re: Blucuda413] #751648
07/18/10 11:42 PM
07/18/10 11:42 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
The old D/C one`s always worked for me.......
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Post deleted by moparts [Re: w2dak394] #751649
07/19/10 09:23 AM
07/19/10 09:23 AM
Re: valve covers for w2 heads #751650
07/19/10 09:57 AM
07/19/10 09:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the reverse lip MP covers on all of my stuff
but I mill the top off to help lighten them up
Re: valve covers for w2 heads [Re: MR_P_BODY] #751651
07/19/10 06:28 PM
07/19/10 06:28 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Edelbrock elite valve covers fit over just about anything out of the box.
Re: valve covers for w2 heads [Re: chryco] #751652
07/19/10 07:26 PM
07/19/10 07:26 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd sure like to find a set of those covers!!
Nautilus Racing-
Re: valve covers for w2 heads [Re: w2dak394] #751653
07/21/10 11:30 PM
07/21/10 11:30 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
T&D, MP Cast with 3/8" thick Mister Gasket...
Re: valve covers for w2 heads [Re: 74_360_Cuda] #751654
07/22/10 07:49 AM
07/22/10 07:49 AM
London, England
Gavin Offline
Gavin  Offline
London, England
I'm planning to use stock steel covers with my W2's & MP Blue rockers - is that a plan that can work? I already assumed that I'll need to make up some spacers?
