Broke Another Flex Plate Today !!
#750730
07/17/10 08:17 PM
07/17/10 08:17 PM
Posts: 1,288 Oregon
sg66mopar
Two weeks ago at the Division 6 points race at Woodburn Dragstrip we had the valley plate seal go away in the semis, cooked the trans fluid and had most of the pan bolts back out so the engine and trans both were puking oil. Well, we made it to the semis so it wasn't all bad. So for the last few days I've been working on the whole program to get ready for the Mopar Nationals at Woodburn Dragstrip and the Division race that's coming up in Spokane. Pulled the trans pan and checked things out in there. Put in a new gasket and changed out some bolts I didn't like. Pulled the oil pan, put in a different style gasket and Permatex Ultra Grey on all the pan bolts. Pulled the new MSD Pro Billet distributor, took it apart and locked the timing. Installed a stop collar on the distributor to make the timing more stable. Looked like I might have had all the little problems fixed for now so I hooked up the trailer, got the camper all loaded with food etc. All ready to go to the track tonight and be ready for the Mopar race tomorrow. WRONG!!! Got in the car, cranked the engine a few revolutions (dead cold), pumped the gas 1 time then hit the ignition switch. 1 big sneeze and CLUNK!!! Took a tooth off the third flex plate this year. I think my racing career is close to being over. The joke this year (no joke to me) is that the car will come home broken from every race. Well, this time it didn't even get to the track!!
Re: Broke Another Flex Plate Today !!
[Re: sg66mopar]
#750732
07/17/10 08:50 PM
07/17/10 08:50 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Locking out the distributor did that.
RIP Monte Smith
[Re: CompWedgeEngines]
#750733
07/17/10 09:17 PM
07/17/10 09:17 PM
Posts: 1,288 Oregon
sg66mopar
Al, it looks like I'm now an official member (along with Wild Bill) of the BOO-HOO Club. I don't think Bill has a Harley but I'm thinkin' he needs one. I remember you talking about your trip north after your car broke. My wife and I just came back from a 1600 mile trip north to Montana on ours and now it looks like it'll get some more miles this summer. Gotta have somethin' to keep me occupied. Looks like I'll be sending off 3 flex plates to JW on Monday to get new ring gears.
[Re: sg66mopar]
#750735
07/17/10 09:53 PM
07/17/10 09:53 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
This may sound dumb, BUT,, have yor battery LOAD tested!!! I have had problems before, similar to yours, and the BATTERY was JUNK!!!,,,NEW,,but, JUNK!! Under a load at full charge, it would go to 6-7 volts causing starter to pulse.
If you like drag racing, support your local track.
[Re: HEMIFRED]
#750738
07/17/10 10:12 PM
07/17/10 10:12 PM
727 or a glide
[Re: CHAPPER]
#750739
07/17/10 10:13 PM
07/17/10 10:13 PM
Posts: 1,288 Oregon
sg66mopar
Already done that. The first flex plate I broke this year was probably caused by bad batteries. Been fighting this problem all this year so I just put in two new group 31 batteries last month with 1195 cranking amps each, along with a new Powermaster Ultra Torque starter. Checked the voltage at the starter while cranking and it never went below 11.5 volts.
The flex plate I have to use is only 130 teeth and the motor has a bunch of cylinder pressure so it just ain't gonna crank at 30 degrees.
[Re: sg66mopar]
#750741
07/17/10 10:17 PM
07/17/10 10:17 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
are you rolling the motor over and then hitting the ignition????
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: sg66mopar]
#750742
07/17/10 10:21 PM
07/17/10 10:21 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
I run a Glide, TCI adapter and a TCI flexplate. Powermaster starter and a single 900CCA battery, timing is locked at 34 degrees with a crank triger. Never an issue for me. I use to have an issue with my JW flexplate hanging up the starter. After fiddle farting around with it for awhile I bought a TCI flexplate... As for the Harley, heck yeah we enjoy it whenever the chance arises. However we have other car habits as well. Just got the back up Super Streeter running again today. Now to decide if I want to make it out for the Divisional this next weekend in a Chevy
[Re: Al_Alguire]
#750744
07/17/10 10:25 PM
07/17/10 10:25 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
i run 15-1 in my hemi glide and stock starter w notched chevy case. full locked zero problems.. is then starter spaced from the flywheel correctly ?
home of the Sox and Martin Hemi Duster
[Re: sg66mopar]
#750747
07/17/10 10:38 PM
07/17/10 10:38 PM
HEMIFRED
SOUTH JERSEY
i heard there are some issues with those starters using the case without a nose . they have a different pitch to the gears or something is different from factory ones. i had a 400.00 CSR platinum series that i threw in the junk box when it killed the second ring gear. the chevy 12 pitch is not the same as mopar powermaster Quote:
9527-Adjustable Hemi 10T, 12 pitch Chevy pinion Five clocking positions 1.8kw-200 ft. lbs. Weighs 10 lbs.
[Re: HEMIFRED]
#750748
07/18/10 01:57 AM
07/18/10 01:57 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Dick.. Call Olan @ Reactor.. (310) 323-0065 Get an extra ring gear.. They bolt in. P/N: 130EI6H (130 Tooth - 6 Hole) P/N : 130EI8H (130 Tooth - 8 Hole) Used these forever. Great product. Aluminum Re-SFI too. Chris..
