225/70R15 on a 15x5.5 #75073
06/17/08 06:54 PM
06/17/08 06:54 PM
Lexington, KY
MaxPower Offline OP
MaxPower  Offline OP
Lexington, KY
will that wheel work or is it too skinny?
Re: 225/70R15 on a 15x5.5 [Re: MaxPower] #75074
06/17/08 07:50 PM
06/17/08 07:50 PM
Kirkland, Washington
Pacnorthcuda Offline
Look it up on the net but personally I think you are pushing it. I had 205/70's on 5.5 Volare wheels and that was a stretch.
Re: 225/70R15 on a 15x5.5 [Re: MaxPower] #75075
06/17/08 07:52 PM
06/17/08 07:52 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
Goodyear and Firestone both say 6" - seems narrow to me.
Steve
Someday I'll have another C-body.
Re: 225/70R15 on a 15x5.5 [Re: SteveS] #75076
06/17/08 08:08 PM
06/17/08 08:08 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I have 225-70-14s on a 14X5.5" and the are ok.
Re: 225/70R15 on a 15x5.5 [Re: AdamR] #75077
06/17/08 09:39 PM
06/17/08 09:39 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
They'll fit
I used to run 225 60 14 on a 5.5.
It was a 69 dart with a 340.
I'll add that the car had 1 1/8" sway bar added to the front, and 3/4" bar on the rear.
It was the best handling mopar I'd ever driven, both before then, and since then.
Re: 225/70R15 on a 15x5.5 [Re: MaxPower] #75078
06/17/08 09:59 PM
06/17/08 09:59 PM
Careful with "they'll fit" --fitting and performing are two very different things. A skinny wheel (relative to tire) will have a LOT of roll when side forces are applied.
Yes they will 'fit' but the tire is not likely to perfrom anywhere near its optimum when mounted in this manner. Just my two cents!
Re: 225/70R15 on a 15x5.5 [Re: AdamR] #75079
06/17/08 10:13 PM
06/17/08 10:13 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I run 22570R15 on factory 7" wheels.They fill out better compared to narrower rims.
Minimum width for 22570R15 is 6" and maximum permitted is 7-1/2 and 8"
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: 225/70R15 on a 15x5.5 [Re: 68Cbarge] #75080
06/17/08 10:26 PM
06/17/08 10:26 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I work at a Goodyear tire garage.
From my "book"
