Drag radials, or slicks, and why???
#750401
07/17/10 01:22 PM
07/17/10 01:22 PM
Posts: 644 Owego, NY
JBurch
Owego, NY
I find myself in need of new tires. Currently have M/T drag radials, 275/60x15, the biggest tire I can currently get under the car. Any thing bigger WILL rub.
I can't say that I know a lot about tires other than usually they are round, hold air, and some are stickier than others.
This is the second pair of M/T's I've had on the car, they seem to work very good, but I have no frame of reference to compare them to other than an ordinary street tire which is really no comparison.
I have heard that drag radials are more sensitive to track prep (lack there of) than a regular slick (again, no frame of reference); would a slick give more consistent launches? I've had a best of 1.4550 60ft (local 1/8th mile track) and seem to be holding in the 1.48-9 zone at the local 1/8th mile track, back on Father's day went to the local 1/4 mile track and had a best of 1.5312 (second time trial, different lane than first, had 1.6740 then)and then they plunged to 1.7991 (same lane as 1.53)and the right lane went to 1.8561, I felt like I was on ice, just no bite. All cases same launch procedure, 16 psi in the tires.
I'd like a tire that gives consistent performance round after round (if I can get that far) cuz I'm not smart enough, nor talented enough to adjust myself and be consistent! When I drive the car, I stand on it as hard as I can, cuz that's all I KNOW. Any help will be greatly appreciated, thanks.
Jim Burch
Re: Drag radials, or slicks, and why???
[Re: JBurch]
#750404
07/17/10 02:03 PM
07/17/10 02:03 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
The drag radials seem to be great on street cars. We run them on a '70 charger with the 472 Hemi, and they work well enough to have broken three rear ends and one drive shaft. I don't think they will last as long as slicks will. I see a lot of guys buying new ones pretty quick in the higher hp cars. We have not worn ours out yet, but we don't have a lot of runs on them either.
I will say if your going to do a fair amount of drag strip passes, slicks work, and they will last a lot longer.
I have a set of 11.5x 29.5's that fit the same car as our 50 series drag radials. You seem to be local, Oswego correct...LMK. Slicks can be very consistent, but there is a bunch you have to do round to round to be consistent.
Having a good cooling system and launching at the same temp and rpm every round is a big one.
[Re: hp340nos]
#750406
07/17/10 02:29 PM
07/17/10 02:29 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Despite why tire company's and people claim, a drag slick is the best tire for traction. For a car that is strictly a race car, doenst need to fit into a class rule for tires, I dont see why anyone wold choose a DOT approved tire, or some drag radial
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: JBurch]
#750408
07/17/10 06:09 PM
07/17/10 06:09 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
jim,let me know ,when to stop by with them,check your email,ive only run m/t slicks and radials,i have tried hoosier dirt track tires also,they werent consistent for me mike
