Trans Fluid Type? #75038
06/17/08 03:48 PM
06/17/08 03:48 PM
Friendsville, TN
Reverend_Ron Offline OP
super street
super street
Friendsville, TN
I'm just getting back into playing with these old classics! In regards to transmission fluid, didn't I use to buy ATF? Then didn't it go to Dexron II?? I'm too old to remember -but what do I buy now-a-days for my old 1971 727's?
Thanks,
Ron
Re: Trans Fluid Type? [Re: Reverend_Ron] #75039
06/17/08 03:51 PM
06/17/08 03:51 PM
NY usa
540challenger Offline
NY usa
Dexron 2 is now replace with dexron 3 you can run that in your 727.
You can run a number of other ones but that is another ball game
Re: Trans Fluid Type? [Re: Reverend_Ron] #75040
06/17/08 03:53 PM
06/17/08 03:53 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Dexron for street
Type F for race
Re: Trans Fluid Type? [Re: GTXKen] #75041
06/17/08 03:55 PM
06/17/08 03:55 PM
GTXKen Offline
super gas
GTXKen  Offline
super gas
The latest Dexron is VI and I believe is synthetic
Re: Trans Fluid Type? [Re: GTXKen] #75042
06/17/08 06:05 PM
06/17/08 06:05 PM
i just switched to castrol type f from the castrol atf +4
atf+4 has extra lubricant,it will keep your transmission parts fresh and clean, i switched to type f for racing as it has a bit more grit to help clutches and i feel a firmer shift.for the street atf +4 for sure.
