Too much pressure? #750245
07/17/10 09:38 AM
07/17/10 09:38 AM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
I just put a mechanical oil pressure gauge on my 65 383. Started it up and at idle (~900) it's reading 78 lbs. Seems kinda high compared to my 67 440. Any issues with too much pressure?
Re: Too much pressure? [Re: JM67RT] #750246
07/17/10 10:50 AM
07/17/10 10:50 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Lol, isn't it amazing to see what the actual pressure of the system is. Should be no problem other than the extra effort the oil pump is using to maintain that high pressure. Change the oil, cold start the oil pressure can easily hit 100. My SRT 10 runs at 90 to a 100 when cold and thats with 0w40 oil. The chevys with there crappy bearings used to wash the main bearings out with to much pressure, but I haven't heard of a case in years.
Re: Too much pressure? [Re: JM67RT] #750247
07/17/10 10:54 AM
07/17/10 10:54 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
No issues other than the 1/2 hp extra it takes to drive the pump at 100 psi compared to 65 psi.
High volume pumps tent to be 80 at idle cold 100 t0 110 if you rev it up a bit. drove mine like that for 25 years (110 out the end of th quarter) but now use a 21550
http://www.summitracing.com/parts/MIL-21550/
or
http://chucker54.stores.yahoo.net/milbrbadregk.html
at mancini's and set the by pass to 70 lb. does not affect hot idle as the by pass is not funtioning then
I may set it down to 55 lb.
Re: Too much pressure? [Re: Dodgem] #750248
07/17/10 12:40 PM
07/17/10 12:40 PM
Westchester, NY
JM67RT Offline OP
JM67RT  Offline OP
Westchester, NY
Thanks guys. I took it out for a ride and it settled down to 55 when warmed up. I think I'm good. Now if I could only cool it down...but that's another post.
Re: Too much pressure? [Re: Dodgem] #750249
07/17/10 01:24 PM
07/17/10 01:24 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
What do you mean .... 1/2 the horsepower ... or 1/2 horsepower ?
I would say it would be ONE HALF the HP to drive the pump at 65 vs 100 psi.
PLUS there is the factor of all that uNnecessary Xtra oil flying around.
.... 80-100 psi is in no-way needed in any application I can think of.
Re: Too much pressure? [Re: dOc !] #750250
07/17/10 02:02 PM
07/17/10 02:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
He said a 1/2 hp loss.
Re: Too much pressure? [Re: stumpy] #750251
07/17/10 02:26 PM
07/17/10 02:26 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
GRUMPster ..... a .5 horsespower loss ? .... in your dreams !!
If you believe that ... you need your daily after-noon seasoned-citizen NAP !!
Re: Too much pressure? [Re: dOc !] #750252
07/17/10 03:11 PM
07/17/10 03:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What are you talking about? please quit snorting those resin fumes before you post. You're rambling again. It doesn't matter because the problem is fixed anyway.
Re: Too much pressure? [Re: stumpy] #750253
07/17/10 06:37 PM
07/17/10 06:37 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
What the fugg is wrong with you ? ... I didn't rattle-your-cage.
What am I talking about ? ...TOOOO much pressure .... and the horsepower drain it is. And if you truly think that it takes only 1/2 of 1 horsepower to run an oil-pump MORE to 100 psi in a HP engine .. vs a steady 65 psi .. then you need to go back to back to trade-school and take a class of Automotive Engines 101.
The resin fumes ? .. try some yurrself ... maybe it would mellow your sour-ball self. Rambling ? ... everything points at YOU
Re: Too much pressure? [Re: dOc !] #750254
07/17/10 07:42 PM
07/17/10 07:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This jerkoff reply to me repeating what was said rattled my cage. It wasn't necessary and rather childish. Maybe you should stop and think before typing. As long as I get replies like this from you I will give it right back to you Mr.Know it all.
Re: Too much pressure? [Re: stumpy] #750255
07/17/10 09:19 PM
07/17/10 09:19 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Me .... a KNOW IT ALL ? .. I have never come across like that at all. A good man knows his limitations ...and that is me in so many ways.
If you give me a .... and I have not even addressed you in any ways ....you will get-it-back in-spades.
And I stand-by my statement about too-much-pressure.
Re: Too much pressure? [Re: dOc !] #750256
07/17/10 10:09 PM
07/17/10 10:09 PM
Under My Car
Mopar_Country Offline
Under My Car
It does take more than a half horse but CERTAINLY not half of all horsepower.
Here is some readin'
http://www.motortopia.com/dragracer/feat...rmance-dyno-58/
Re: Too much pressure? [Re: Mopar_Country] #750257
07/17/10 10:52 PM
07/17/10 10:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If is all it takes to get a childish reply like you made then you need to take a chill pill. Your way too sensitive.
Re: Too much pressure? [Re: stumpy] #750258
07/17/10 11:05 PM
07/17/10 11:05 PM
Under My Car
Under My Car
Are you referring to me or doc? I was simply trying to tell doc is does not use half of all available horsepower like he is saying.
Re: Too much pressure? [Re: Mopar_Country] #750259
07/18/10 01:53 AM
07/18/10 01:53 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Interesting... But I don't think a 1000hp motor dynoed between 5500-7500 rpm really applies to many of us here!
Re: Too much pressure? [Re: DaytonaTurbo] #750260
07/18/10 09:52 AM
07/18/10 09:52 AM
Under My Car
Under My Car
No, I'm sure it doesn't. I know not in my case, but even if we are running a 400 HP engine I can't imagine it taking 200 of it to run a high volume oil pump.
Re: Too much pressure? [Re: Mopar_Country] #750261
07/18/10 09:55 AM
07/18/10 09:55 AM
St. Leonard
Curt Hildebrandt Offline
St. Leonard
It might just mean, 1/2 hp to drive the pump???? But them how would one measure parasitic drag from an oil pum??
Re: Too much pressure? [Re: Curt Hildebrandt] #750262
07/18/10 12:41 PM
07/18/10 12:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
well I just said 1/2 hp more as say it take 1/2 hp to drive the pump at 65 lb it might be 1 to drive it at 110?? I don't know what it takes but my 1/2 drive drill (maybe 1/3 horse??) would drive mine to over 100 lb before I put the adjustable relief spring in.
Maybe at RPM it takes more but load will not increase once pump starts to by pass???
anyone did dyno time lowing pressure between runs??
Hears what Dvorak says
3. Oil pressure is the horsepower’s enemy. If you can get the oil to return to the sump and pick up and not uncover the screen, a good stock eliminator or super stock eliminator can survive on as little as 6 or 7 pounds per 1,000 RPM. That means oil pressure between 42 and 49 pounds at 7,000 RPM will live and the freed up horsepower can be dramatic. In step 2 above where we discuss changing the viscosity of oil to free up horsepower also reduces the oil pressure. That’s where some of the gain comes from. Some engines like our big block Chrysler, has an external oil pump with an easily accessible relief valve. It takes a couple of minutes to make the oil pressure adjustable by drilling and tapping the pressure relief cap and inserting an adjuster like is used on a rocker arm, where the ball end plugs into the spring below. Crack the nut and turn in or out the adjuster. You can make it work like each full turn equals 10 pounds of oil pressure. The combination of the oil, oil temperature and the adjustment will enable the racer to bring the oil pressure to the bare minimum. Lower pressures than I have here are more risky but respond in ET. It is good to consult with your engine builder before you exercise this option
Re: Too much pressure? [Re: Mopar_Country] #750263
07/18/10 03:23 PM
07/18/10 03:23 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
MC ....I am not suggesting AT ALL that it takes "1/2 the avail HP" to drive the pump. I honestly do NOT know.
I am just debating the suggestion that it takes just 1/2 of 1 HP to drive the pump to 100 psi ... vs 65 psi.
Someone asked .... well HOW do you determine how-much draw there is. Just have a 110v driven oil pump on a dyno.
My guess ... 65 psi at 6,000 rpm .... 25 horsepower ? 100 psi at 6,000 ? .. 35-40 hp.
Re: Too much pressure? [Re: Dodgem] #750264
07/18/10 03:55 PM
07/18/10 03:55 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
GOOD stuff D e ......
I had not seen that observation on the part of Double D ... but it seems to agree with a article that WJ did for National Dragster some years ago. He runs his PS motor up to what ? .. 9k ? ... and he uses 50 psi.
NOT ONLY less HP to drive the pump .. the lower psi throws less oil around in the crankcase ... that the crank and rods have to pass-through.
