Help........ Dodge Neon #750020
07/17/10 12:38 AM
07/17/10 12:38 AM
Somewhere Over the Hill
Mr. Dodge Offline OP
I got a 2000 Neon as my commuter, well it developed a real inconvenient problem, with the A/C going it causes the wipers to activate, well its moved on to the wipers randomly cycling. Would it the A/C switch on the fritz or is it the headlight switch?
Thanks guys
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
Re: Help........ Dodge Neon [Re: Mr. Dodge] #750021
07/17/10 09:37 AM
07/17/10 09:37 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Bad grounds will cause a multitude of issues. I'd check at the bottom of the column where wire come out. You just might have something rubbed bare. Odd that it makes the wipers run.
Also, trace back from the compressor to see, again, if there's something making contact. Start w/the easy things first. Might even be something behind the fuse block doing this.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Help........ Dodge Neon [Re: Magnumguy] #750022
07/17/10 09:47 AM
07/17/10 09:47 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Interesting, todays cars run a lot of the functions thru the computer. Not 100% sure in the case of a 2000 Neon, but for some reason manufacturers decided having everything go thru the computer is a "good thing".
Hmm, dug into my Neon FSM, 2004 model, seems the wipers are self contained, IOW no computer involved there. Only thing I can figure is there is a short somewhere causing the wiper's to activate when the AC is on.
Don't be the exception.
Re: Help........ Dodge Neon [Re: Supercuda] #750023
07/17/10 08:57 PM
07/17/10 08:57 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the old phanthom wipe....happens on my caravan....they say its the switch in the column...
