Lower control arms for A body #749772
07/16/10 07:00 PM
07/16/10 07:00 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
Is there any difference between a 1972 dart and a 1973 dart...i.e. mainly the taper where the ball joint attaches...I just need to know weather or not to purchase a pair...I am swapping to a Aspen brake system and have aftermarket upper control arms but did not even think to see if there was a difference. I know this has been probably covered before but I am in a hurry and had no time to search. I know there is a difference in 72 and 73 ball joints as far as bolt spacing but was not sure of the stud.
Thanks in advance
Re: Lower control arms for A body [Re: friesza] #749773
07/16/10 08:47 PM
07/16/10 08:47 PM
NY NY
3
340duster340 Offline
NY NY
unless you are running a sway bar (mounting tabs are different), i think they are the same.
Re: Lower control arms for A body [Re: 340duster340] #749774
07/16/10 08:50 PM
07/16/10 08:50 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
They are. Sway bar mount tab locations are in one area from 1965 to 1972, and then from 1973 to 1976.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Lower control arms for A body [Re: hemi71x] #749775
07/16/10 08:56 PM
07/16/10 08:56 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
Thanks for the info...just saved me 80 bucks....I will just clean up the ones I have and box them and just get the 73 up ball joints.
