Need help on a/c wiring #749438
07/16/10 09:04 AM
07/16/10 09:04 AM
Ga
roadrunner7853 Offline OP
Ga
I have a 69 rr with air. When you turn the a/c on, the tach goes dead. It has a new a/c switch and the only way to get the tach on is wiggle the off button on the a/c?
Re: Need help on a/c wiring [Re: roadrunner7853] #749439
07/18/10 09:10 AM
07/18/10 09:10 AM
Ga
Ga
I had time to check a few more things sat. If you run a direct wire from the battery to the tach, turning the a/c on want affect the tach. Could the voltage drop cause the tach not to work? It's a factory tach.
