will a 69 B-body front sway bar fit a 65?
#747960
07/14/10 10:34 AM
07/14/10 10:34 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Subject says it all. Can a stock 69 front sway bar fit on a 65 b-body K frame? I know the lower control arms with tabs would have to be installed (or have tabs welded). No doubt the K frame isn't drilled for the mounts but that's an easy fix.
Re: will a 69 B-body front sway bar fit a 65?
[Re: AndyF]
#747962
07/14/10 10:59 AM
07/14/10 10:59 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Feets Im thinking about doing the same on my 65.I have the complete setup in the 66 Charger my kids stripping.Shouldnt be too hard to pull the bar assy and lower arms and put them in.Rocky
Chrysler Firepower
[Re: AndyF]
#747963
07/14/10 11:13 AM
07/14/10 11:13 AM
feets
Senior Management
Senior Management
Irving, TX
Thanks. I've already got one on the hot rod but it's a 69 K-frame.
[Re: feets]
#747965
07/15/10 08:23 AM
07/15/10 08:23 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Aren't there aftermarket sway bar setups available for early B's?
This is the land of the free
because of the brave
[Re: rbstroker]
#747966
07/15/10 09:21 AM
07/15/10 09:21 AM
feets
Senior Management
Senior Management
Irving, TX
I believe there are setups available. However, if you have an early B and you also have a sway bar you kinda want to use what you've got.
[Re: feets]
#747967
07/15/10 09:36 AM
07/15/10 09:36 AM
therocks
Niles , Ohio
I agree with Feets.I have the complete setup from the 66 Charger for my 65.Its free and my 65 isnt a road racer that needs a heavy sway bar.Rocky
Chrysler Firepower
[Re: therocks]
#747968
07/15/10 12:15 PM
07/15/10 12:15 PM
We put a 66 Charger front sway bar on my brother's 62 Dodge. Used the Charger lower control arms, and drilled the (original 62) crossmember for the sway bar bracket bolts, and it bolted in.
The factory pre-66 sway bar clamped to the strut rods, so using the 66-up style bar doesn't look original, but it fits.
