dana 60 question?? #747733
07/13/10 08:19 PM
07/13/10 08:19 PM
nc
trex Offline OP
trex  Offline OP
nc
i have a dana 60 out of an old ford truck i want to cut it down to fit my 70 cuda the axles are 16 spline and the guts are new. 355 gear posi is this a good rear to use? also who makes 16 spline custom cut axles for this ? and one last question does anyone one know the length cut for each side of the tubes thanks for the help!!
Re: dana 60 question?? [Re: trex] #747734
07/13/10 10:04 PM
07/13/10 10:04 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I've never heard of a 16 spline one.
Are you sure you are counting then right?
16 would be very small.
Re: dana 60 question?? [Re: fox] #747735
07/13/10 10:11 PM
07/13/10 10:11 PM
BDW Online content
BDW  Online Content
Copied from Dr Diff:
Dana 60 rearend specs:
'66 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 U-bolt yoke
'67 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 strap yoke
'68-'69 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 23 spline power-lock sure-grip, 7290 yoke
'70 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 35 spline power-lock sure-grip, 7290 yoke
'71-'72 B-body 57 7/8" housing, 63" axle flange to flange, 47.3" perch, 35 spline track-lock sure-grip, 7290 yoke
'70 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline power-lock sure-grip, 7290 yoke
'71 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline track-lock sure-grip, 7290 yoke
Re: dana 60 question?? [Re: trex] #747736
07/13/10 10:27 PM
07/13/10 10:27 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Here is some info about the conversion. The article states that you need to use your existing rear as a guide.
http://www.moparmusclemagazine.com/techa...uild/index.html
Re: dana 60 question?? [Re: fox] #747737
07/13/10 10:43 PM
07/13/10 10:43 PM
nc
trex Offline OP
trex  Offline OP
nc
yes !! very corse spline 16 i checked they did make them
Re: dana 60 question?? [Re: trex] #747738
07/13/10 10:55 PM
07/13/10 10:55 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
Fords had the 16 splines.
Re: dana 60 question?? [Re: trex] #747739
07/14/10 06:47 PM
07/14/10 06:47 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Contact Dr. Diff on this board. You most likely have a very good sure grip unit (as in Powr Lok) and he can supply you with 35 spline side gears and axles for it. You do not want to stick with 16 spline axles but it can easily be upgraded.
Sheldon
Re: dana 60 question?? [Re: trex] #747740
07/14/10 06:56 PM
07/14/10 06:56 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Is this a full floating rear end? You will need new axle ends to work with a semi floating car axles.
Also, those axle tubes are probably brutally thick. Might not be a bad idea to drill out the plug welds and press the old tubes out and replace them with thinner wall tubes. It's not really necessary, just a your preference if you want a lighter axle assembly.
