20 or 24 gauge Wheel tubs? Worth the price #747425
07/13/10 01:05 PM
07/13/10 01:05 PM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
I was looking at the summit racing wheel tubs, and they are priced nicely for around $75 a pair. The issue I see is they are only 24 gauge sheet metal. Other places are $50 more a pair, but are 20 gauge instead. Is it worth the extra $50 for that little amount of thickness? This is on a street car that is getting mini tubbed with street tires.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: 20 or 24 gauge Wheel tubs? Worth the price [Re: jrlegacy23] #747426
07/13/10 01:09 PM
07/13/10 01:09 PM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
24 gauge is really thin steel. I'd avoid them.
You can jab a screwdriver through 24ga without much of a swing.
Re: 20 or 24 gauge Wheel tubs? Worth the price [Re: GregCon] #747427
07/14/10 01:51 AM
07/14/10 01:51 AM
Cooperstown, NY
Cooperstown, NY
Is 20ga much stronger? Or should I look for thicker?
Re: 20 or 24 gauge Wheel tubs? Worth the price [Re: jrlegacy23] #747428
07/14/10 06:33 AM
07/14/10 06:33 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
20 is probably OK, especially if the have some bead rolling in them (?). The stock sheetmetal is probably 18-19 ga so 20 is not far off.
Personally when I have done tubs in a street car I treat them like a factory wheelhouse; I usually undercoat the outside and use carpet or Dynamat on the inside. It adds a lot of noise reduction and helps prevent dents and dings.
Re: 20 or 24 gauge Wheel tubs? Worth the price [Re: GregCon] #747429
07/14/10 11:46 PM
07/14/10 11:46 PM
Cooperstown, NY
Cooperstown, NY
Thanks for the info.
Re: 20 or 24 gauge Wheel tubs? Worth the price [Re: jrlegacy23] #747430
08/16/10 06:06 PM
08/16/10 06:06 PM
Cooperstown, NY
Cooperstown, NY
I have found a set of 16 guage tubs for $129. here is a link:
http://store.gaugemagazine.com/32-round-universal-wheel-tub.aspx
