E-body rear floor braces - where do they go? #747396
07/13/10 12:33 PM
07/13/10 12:33 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Do they weld under the shock mount crossmember, or somewhere else? It kind of looks like they should be there, as that's where the trunk floor and the floor panel meet. Or could they be welded inside the trunk area?
Thanks!
Re: E-body rear floor braces - where do they go? [Re: sharpie] #747397
07/13/10 12:38 PM
07/13/10 12:38 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
They run from the tail panel lower seam to just behind the shock mount crossmember IIRC. Been a little while but I don't recall having to touch the crossmember when I did them. I sectioned the new floor pan just behind where the reinforcements were welded I think.
Re: E-body rear floor braces - where do they go? [Re: sharpie] #747398
07/13/10 02:10 PM
07/13/10 02:10 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Thanks!
Working on the new catalog?
