5/16" vs 3/8" fuel line #745708
07/11/10 06:19 PM
07/11/10 06:19 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I have a 67 Dart (street car)with a 340, nothing radical just a little above stock with mild cam headers and eddie intake, 750 (3310)holley. 3000 stall converter with 3.91 gears. I am going to replace all the fuel lines, tank and sending unit.
My question is while I am dong this should I upgrade to the 3/8" lines and pickup or stick with the 5/16" system. What are the limits of the 5/16" lines as far as restricting power?
Re: 5/16" vs 3/8" fuel line [Re: mopars rule] #745709
07/11/10 06:42 PM
07/11/10 06:42 PM
south carolina U.S.
DOUGG Offline
DOUGG  Offline
south carolina U.S.
IF YOU ARE GOING TO CHANGE IT ALL ANYWAY, I WOULD UPGRADE TO THE LARGER LINE AND SENDING UNIT. IF YOU KEEP ADDING POWER TO YOUR CAR YOU WILL FIND THE LIMIT ON THAT SMALLER LINE. THERE'S NOTHING WORSE THAN DRIVING YOUR CAR TO THE TRACK, PULLING A CAR LENGTH ON A TRAILERED CAR WITH SLICKS ONLY TO LOSE TO HIM BY 4 LENGTHS BECAUSE YOU COULD'NT GET ENOUGH FUEL IN THIRD GEAR. BIGGER IS BETTER.
Re: 5/16" vs 3/8" fuel line [Re: DOUGG] #745710
07/11/10 07:14 PM
07/11/10 07:14 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
with the above, just not gonna shout it.
Re: 5/16" vs 3/8" fuel line [Re: rrunner] #745711
07/11/10 07:31 PM
07/11/10 07:31 PM
Warner Robins, Georgia
DusterMan Offline
super street
DusterMan  Offline
super street
If you are taking everything out and replacing them it wont
hurt. When I had my Duster 360 I ran 11.60's @ 116 MPH and
I was running stock fuel lines and a mech pump and never had
any problems.
Pete:
2003 Dodge Quad 2500 Hemi
69 RoadRunner 4 sp Alpine White
2019 Dodge Charger
Re: 5/16" vs 3/8" fuel line [Re: DusterMan] #745712
07/11/10 08:36 PM
07/11/10 08:36 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Then there's guys like me and I just replaced all the fuel lines on my 360 powered truck with AN10...
Re: 5/16" vs 3/8" fuel line [Re: Dragula] #745713
07/11/10 10:27 PM
07/11/10 10:27 PM
alabama
mopar addict
mopar addict
alabama
I was leaning toward the 3/8" line a little anyway, just wasn't sure. Guess I will go ahead and do it. Thanks fellas.
Re: 5/16" vs 3/8" fuel line [Re: DOUGG] #745714
07/11/10 10:56 PM
07/11/10 10:56 PM
Under My Car
Mopar_Country Offline
Under My Car
Why you yelling?
