Caster camber #745023
07/10/10 10:09 PM
07/10/10 10:09 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Do you guys set for max positive caster & not worry too much regards camber?...1/4 mile racing.
Been all over this car & it's still wanders down track (68 charger)
TIA
Re: Caster camber [Re: 602heavy] #745024
07/10/10 10:34 PM
07/10/10 10:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I set max caster and 0 camber... on my car(strut) I
have the caster at 10* with 0 camber... check your
toe curve... if it goes toe out at all it will wander
or if its bad enough it will dart back and forth
Also set the front end with the body 1" up to simulate
down track
Re: Caster camber [Re: MR_P_BODY] #745025
07/10/10 10:45 PM
07/10/10 10:45 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
down track
But with stock suspension you wont see 10* positive caster. 5* would be fine.
Also, Have you replaced the inner lower control arm bushings. They are over looked alot and can cause a considerable amount of steering control travel at the top end if wore. mike
Re: Caster camber [Re: Sport440] #745026
07/10/10 11:02 PM
07/10/10 11:02 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Renewed all front end a few years ago , won't hurt to check again..................seems every time i come back from the track front ride height has dropped an inch or so on the right hand side , these are the 1" torsion bars fitted new not long ago , if this keeps happening there won't be any thread left for adjustment
