Re: Chronic lean condition please help
[Re: 67Dart383]
#744855
07/10/10 05:17 PM
07/10/10 05:17 PM
Posts: 7,506 Az
Crizila
Az
If you are sure you have no vacuum leaks, you might want to go a range or 2 colder on the plugs. The new alchol ladin fuel doesn't color plugs well.
Fastest 300
[Re: Quicktree]
#744859
07/10/10 07:44 PM
07/10/10 07:44 PM
Quicktree
[Re: 67Dart383]
#744860
07/10/10 07:57 PM
07/10/10 07:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Also make sure the brake cleaner/carb cleaner is flammable ... I just went through this with a non flammable spray(it wont rev up cause its not burning) if its that lean you really didnt make a pass... how is the supply(filter and pump)have you done a flow/ volume test
[Re: 67Dart383]
#744863
07/11/10 12:30 AM
07/11/10 12:30 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I got a 67 Dart 383 10.0 motor mild cam ported polished 452 heads. I got a 750 holley with a proform body. The plugs are white no matter what I do. Right now it has 82 jets in the front and 91 in the rear and the plugs are still white. The idle mixture screws are backed out more then normal to get 12-14 pounds of vacuum. It acts like its got a vacuum leak but I have poured carb cleaner all over the intake and also used a propane torch around the intake with no changes. Anybody got any suggestions on what is going on?
If you don't have a vacuum leak & rule that out, upping the main jetting does nothing for the idle curcuit, sounds like you need to either increase the IFRs size or decrease the IABs, your main jets are WAY too fat now, start off with the factory PF recammendation jetting for the 750, should be 74/82, then after you get the idle curcuit currected, then jet for "best" mph at the track.
