LEAKY BREATHER!!! #744839
07/10/10 04:35 PM
07/10/10 04:35 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Are there any adverse effects to running a breather on one valve cover and not the other? I noticed today that the breather on the passenger side was dripping onto the headers. I cleaned it up and put a screw-on solid cap. There is a K&N breather on the driver's side. Should I put a breather back on,or can I leave the solid cap on? Thanks Guys! RandyB
Re: LEAKY BREATHER!!! [Re: Labratt] #744840
07/10/10 04:53 PM
07/10/10 04:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Only if the one breather cant handle the flow/volume
then it will pressurize the crank case
Re: LEAKY BREATHER!!! [Re: MR_P_BODY] #744841
07/10/10 05:33 PM
07/10/10 05:33 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Here. No leaks.
SRT DEMON ONE SEAT
Re: LEAKY BREATHER!!! [Re: MR_P_BODY] #744842
07/10/10 05:33 PM
07/10/10 05:33 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have had this problem in the past. I ran two breathers to be sure no pressure built up in the crankcase. I cut the top off 2 old heavy tube socks and slipped them over the breathers. Worked great to catch the excess oil and stop any drips. Kinda' poor man's Outer Wear breather covers!
If you like drag racing, support your local track.
Re: LEAKY BREATHER!!! [Re: Labratt] #744843
07/10/10 05:34 PM
07/10/10 05:34 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Absolutely! The side of the engine with the breather will be heavier, thus causing the engine to go out of balance and create 6th order harmonics throughout the driveline, resulting in pre-mature wear of the deltoid spurving bearings, which are encapsulated by the differential girdle caps.
So, the bottom line is, you need a breather on both valve covers.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: LEAKY BREATHER!!! [Re: DusterDave] #744844
07/10/10 05:44 PM
07/10/10 05:44 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
To a certain extent yes, beyond that no
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: LEAKY BREATHER!!! [Re: DusterDave] #744845
07/10/10 06:08 PM
07/10/10 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... I cant even spell half of those words
Re: LEAKY BREATHER!!! [Re: DusterDave] #744846
07/10/10 06:50 PM
07/10/10 06:50 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Yeah, but you can compensate for that by closing one eye and squeezing your butt cheeks together on the shifts
Re: LEAKY BREATHER!!! [Re: emarine01] #744847
07/10/10 07:32 PM
07/10/10 07:32 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
To a certain extent, but it depends on which eye in relation to the breather location. Squeezed butt cheeks are dependent upon ET. Coupled with the drop in rpm's from the gear change, the combined modial interaction of magneto reluctance and capacitive diractence within the ignition system will cancel the 6th order harmonic oscillation, enabling the spurving bearings to remain in a perpendicular centerline with the driveshaft. Thus, side fumbling of the spurving bearings is effectively eliminated.
Re: LEAKY BREATHER!!! [Re: DusterDave] #744848
07/10/10 07:47 PM
07/10/10 07:47 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
..... Ok You win...... I think you broke my spell check
Re: LEAKY BREATHER!!! [Re: emarine01] #744849
07/11/10 12:15 AM
07/11/10 12:15 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
You guys are too much! I definately don't want to blow a canootin valve,or spin a muffler bearing because of a breather! Guess I'll replace it monday! Thanks for all the Einsteinesque theoretical explainations,Dave! RandyB
