Re: car dogtracking
[Re: correctdirection]
#744692
07/10/10 12:43 PM
07/10/10 12:43 PM
Posts: 2,527 PA
moparacer
PA
I have went though this with my car before and the only way I found to get it close to perfect is to jack it up and level it, find the chassis centerline and chalk-line it on the floor, then snap a perpendicular line off of that, then drop a plumbob and string off the axle centerlines.
I know its a pain but its the only way to get it perfect.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: car dogtracking
#744694
07/10/10 02:19 PM
07/10/10 02:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is the wheelbase the same side to side? Someone told me that it is sometimes different
Is this a A-body... A-bodies have a wider front than the rears and will make it look like its tracking weird... have to look at both sides while its going down the road
Re: car dogtracking
#744696
07/10/10 02:42 PM
07/10/10 02:42 PM
MR_P_BODY
yes it is a 68 Dart. Car is definatly dogtracking.I just cant figure out why it started. Car never done it with superstock springs.
Most of the time the rear end is not straight... measure the axle to the front spring mounts to see if its equal you could have different length springs
Re: car dogtracking
[Re: smokinwoody]
#744701
07/10/10 03:27 PM
07/10/10 03:27 PM
Posts: 7,506 Az
Crizila
Az
Don't want to be an alarmist, and I agree with checking the easy stuff first, but it sounds like you are getting past that point. Also don't know how much HP you are making ( assume a lot more than the A body was intended to handle if you are going to Cal-tracs). When all your suspension checks are good, you should start looking at the frame. Any slight wrinkles in the trunk floor or rear fenders around the fender wells are tell-tail signs.
Fastest 300
