How far back does the fan need to be from the radiator? #744592
07/10/10 09:26 AM
07/10/10 09:26 AM
Cookeville
Chilort Offline OP
Will Work For Mopars
Chilort  Offline OP
Cookeville
I'm having a little trouble keeping my old truck cool on these hot hot hot summer days or while sitting in traffic. The temp really wants to creep up. I've got a fan shroud, the rad was re-cored a few years ago, I've got a big 7-blade fan, water pump is new with the anti-cavitation plate, the coolant is a little on the water side of a 50/50 mix but not too much with Water Wetter, t-stat is new and works properly, original factory water pump housing, and the viscus clutch is new and a heavy duty unit.
I've been throwing parts at it and nearly everything I've done has helped but nothing has solved the problem. I'm wondering exactly how far back does the fan and clutch need to be from the radiator? I can squeeze my hand between the fan and the face of the clutch and that's about it (so an 1", maybe 1.5"). Is that too close?
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744593
07/10/10 09:34 AM
07/10/10 09:34 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The fan needs to be a little more than half way in the shroud. If it is, that's all you've got.
- Stu Harmon
Re: How far back does the fan need to be from the radiator? [Re: feets] #744594
07/10/10 09:54 AM
07/10/10 09:54 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Does it heat up in traffic only? If so then it is an air flow problem. Maybe try a "fixed" fan instead of a clutch fan. Does it cool down once moving down the road? If so then your air flow is okay and it is definetly a fan problem. If it stays hot all the time, then look at a lower temp thermostat, a radiator issue, or a lower hose collapsing, or a combination of any of these. (straight water will cool better than an antifreeze/water mix.)
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: How far back does the fan need to be from the radiator? [Re: 68LAR] #744595
07/10/10 10:08 AM
07/10/10 10:08 AM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
I was doing fine on the road until these past few days when the temp hit a hundred. Once it got that hot, it was get hotter and hotter out cruising at full speed. I guess the temp of the tarmac was a lot hotter than the air temp and that didn't help either.
The fan is 1/2 out of the shroud.
The hoses are all new and the lower hose has a wire in it. It doesn't collapse.
The t-stat is a 180* unit. You can see on the temp gauge when it opens up because the temp will go back down a bit but then it just keeps going up and up. I've got a Milodon high flow stat in it but it did the same thing with a regular style stat.
I can control the temp some but opening up the water valve to the heater and kicking the fan on full blast. But that's really not that much fun.
I'm really leaning toward a problem with the radiator.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744596
07/10/10 10:47 AM
07/10/10 10:47 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
How hot is it getting?
- Stu Harmon
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744597
07/10/10 11:14 AM
07/10/10 11:14 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Its sounding form the symptoms that the rad does not have enough capacity or is too small.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: How far back does the fan need to be from the radiator? [Re: HemiRick] #744598
07/10/10 03:08 PM
07/10/10 03:08 PM
Az
Crizila Offline
Crizila  Offline
Az
If it heats up at cruising speeds - 50+, rad is probably too small or you have created issues with the air entry in to the rad or air exit from under the hood. Any changes made in those areas ( spoiler removal, grill blockage, headers, can also have a negative effect on flow.
Fastest 300
Re: How far back does the fan need to be from the radiator? [Re: Crizila] #744599
07/10/10 03:38 PM
07/10/10 03:38 PM
So. Oregon
ron1320 Offline
ron1320  Offline
So. Oregon
Not to hijack the thread, but how much modification can you get away with on the engine before you start having problems with a stock type setup?
How modified is your engine combo?
69 R/T 440
Re: How far back does the fan need to be from the radiator? [Re: ron1320] #744600
07/11/10 01:26 AM
07/11/10 01:26 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Check to make sure your exhaust flapper vlave isn't stuck closed.
If turning on the heater helps drop the coolant temp, you have a cpacity issue with the radiator.
Don't be the exception.
Re: How far back does the fan need to be from the radiator? [Re: Supercuda] #744601
07/11/10 01:32 AM
07/11/10 01:32 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
double check the clutch, i have one of the jaguar units on my RR and it is leaking with about 2,000 miles on it.
Re: How far back does the fan need to be from the radiator? [Re: ademon] #744602
07/11/10 04:08 AM
07/11/10 04:08 AM
overheating at speed, what Crizila and hemirick said. I would toss the stat for 1 day on the off chance it is not opening 100%, might get lucky
Re: How far back does the fan need to be from the radiator? [Re: RapidRobert] #744603
07/11/10 09:50 AM
07/11/10 09:50 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
The factory service manual says the clutch should be no more than 1-1/4" from the rad. My new Hayden HD is about 2". I dug through my spares and found a original 7 blade fan and the shaft on the clutch is about 3/4" longer, which should put me at the correct distance, I'll let you know if it makes a difference when I put it on today!
Re: How far back does the fan need to be from the radiator? [Re: Lee446] #744604
07/11/10 01:38 PM
07/11/10 01:38 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
How far back should the fan be from the radiator? How about as far as the shroud lets it while still keeping the fan 1/2 out of the shroud. Check out a V6 Tbird. The fan is about 12 inches from the radiator, but the shroud is also that long. Make sure your shroud is sealed around the radiator and is is doing what is designed to do: allowing the fan to pull the maximum amount of airflow across the entire surface of the radiator. Also check for clutch slippage/seepage, cold spots in the radiator surface, that would show areas of blockage. Does your radiator look good inside ie. low/no corrosion? Take a STRAIGHT coathanger and put it down one of the tubes, does it go in smoothly? Might just need a rod out or a solid fan coupler.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744605
07/11/10 07:55 PM
07/11/10 07:55 PM
crlush Offline
crlush  Offline
what kind of gauge are you useing (stock or aftermarket) and is it acurate? a friend of mine has a old corvette he said was running hot we checked it with a hand held laser temp gauge and it never ran hotter than 190deg. Im not shure about the history of your truck how long have you had it, but has it run cool in the past? is this a new problem? have you done any hp mods? make shur your gauge is working acurate.
Re: How far back does the fan need to be from the radiator? [Re: crlush] #744606
07/12/10 07:16 PM
07/12/10 07:16 PM
Cookeville
Chilort Offline OP
Chilort  Offline OP
Cookeville
Sorry, y'all for the slow reply. I went on a trip for my 1 year wedding anniversary with my wife to Savannah, GA and we left our electronic devices with access to the internet at home... fun trip.
Anyway, I can't say how "new" the problem is. I never drove the truck in this kind of temperature until this year when my '86 Daytona bit the bullet (going to try to rebuild her but it will be a bit) and I didn't have a great paying job up until last week so a newer car should be in order very soon. In short, I may have had this problem since I bought the truck several years ago and just never knew it. It has been in the mid to high 90s here with heat indexes over a hundred and the air coming up off the interstate is probably pushing boiling.
The details on the build are going to get messy so hold on (but not as modified as Feets):
1968 D100. Engine was recently rebuilt (though not original) and has less than 3500 miles (but is close to 3500 miles). It is a 440, 0.040 over and the pistons are .100 in the hole (reuse - no budget - don't poke fun), with stock rods and a forged crank. Heads are Eddys (purchased a few years ago) that have been milled for a final compression ration of 9.2:1. Cam is a Lunati 60303 with Lunati lifters and Trend custom pushrods because I'm running Harland Sharp rockers (and that's where the budget went). The oil pump was rebuilt to stock specs and I get great oil pressure even without an oil limiter to the heads. I am running full length headers and 2.5" dual exhaust. The torque converter is from Turbo Action. I run a small oil cooler in addition to a deep trans pan. The fan is a 7 blade from a '76 or so Chrysler C-body of some kind. The water pump and t-stat are new Milodon units. The water pump housing is a factory Mopar unit. The fan clutch is a new thermostatic heavy duty unit made by Hayden. It get very stiff when the engine is hot. The fan moves a lot of very hot air. The rad cap is a newer 15-16lb unit that could be found on any Mopar from the 80s and 90s. The carb is the cheapo Holley 750 (74 jets in the front and a plate equal to 75 jets in the secondaries). I run 18* initial timing and 32* total. I have a Mopar Performance dizzy that I've set up based on advice from here. The total timing doesn't come in until 3500 rpm and the vacuum advance has been pulled back quite a bit. Plugs look great (Champion RC12YC).
The radiator itself has been recored. It is from a '68 C-body that had a 440 and AC (according the the part number). Unfortunately, the radiator and engine are not in the same exact orientation in the truck as they were in the car (the rad sits an inch or two higher) and the the fan is a few inches bigger in diameter than what was used in the original application. While I do have a correct fan shroud (in perfect freaking condition), I cannot use it. I ran without a shroud for a long time but when the air temps got over 85 or so I had to add the shroud. I hacked up a shroud from an '80s Dippy. It actually fits very well. I've sealed around the top and bottom with double sticky sided foam tape and the sides are more well sealed than they were in the Dippy.
Because the radiator was a recore (though via a reputable local shop) I am a little worried it wasn't done well and isn't flowing water evenly. I do not have one of those fancy laser guided temp deals so I guess I need to invest in one.
The temp gauge is the stock factory gauge. When things are humming along nicely in cooler weather the gauge points straight up (between the letters "E" and "M" in the word "TEMP). But now that it is warmer moves to the right (past P) and I get nervous. Once again, I guess I need to confirm how hot it is getting but it does want to start pushing out coolant when it gets real hot. I have no puke tank.
Thanks for all the help guys. I guess I have some things to look at.
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744607
07/12/10 07:30 PM
07/12/10 07:30 PM
okla.
O
okie Offline
okie  Offline
O
okla.
On my 340 with the factory ralley gauges it runs on the H when I'm going down the road. I check the actual temp and it is around 190. It never boils over but it always make me worry when I look at the gauge. I run a 160 thermastat new heavy duty clutch fan with a factory shroud and the heavy duty water pump. You can one of the new laser at Napa for about 50 and they are worth it. Good Luck with it! Ronnie
Re: How far back does the fan need to be from the radiator? [Re: Chilort] #744608
07/12/10 11:08 PM
07/12/10 11:08 PM
Arizona
az426john Offline
az426john  Offline
Arizona
It might be worthwhile to make a trip to Harbor Freight and buy an infrared thermometer for about $30.00 then you can point and shoot to get actual temperatures at specific locations and not rely on gages that may or may not be accurate.
Re: How far back does the fan need to be from the radiator? [Re: 68LAR] #744609
07/12/10 11:32 PM
07/12/10 11:32 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
I would never run streight water unless you want your whole cooling system to be rust infested. That is a good way to invent permanent problems. Besides, I always thought that antifreeze helped the water cool the system better, as well as prevent corosion.
DRIVE EM, DONT HIDE EM.
Re: How far back does the fan need to be from the radiator? [Re: ledft79] #744610
07/12/10 11:43 PM
07/12/10 11:43 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Not to hijack, but how close is too close for the fan to be from the radiator? I'm worried about hard braking and a fan munching a radiator.
Re: How far back does the fan need to be from the radiator? [Re: ledft79] #744611
07/12/10 11:48 PM
07/12/10 11:48 PM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
Prevent corosion? Yes. Antifreeze raises the boiling temp of the coolant. It does not make a motor run cooler.
Dakota for life!
