correct tires by decoding buildsheet (please help) #744248
07/09/10 08:34 PM
07/09/10 08:34 PM
MI
AfterHoursResto Offline OP
MI
Can someone help decode my broadcast sheet and tell me what type of tires I need to purchase? I was once told that my Duster should have 14 inch with two thin white stripes on the side wall. Is this true? The broadcast sheet code is T74. This is for a 70 Duster.
Thanks for your help.
Roman Sobilo
Re: correct tires by decoding buildsheet (please help) [Re: AfterHoursResto] #744249
07/09/10 10:13 PM
07/09/10 10:13 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
E70x14 White Sidewall Fiberglass
Re: correct tires by decoding buildsheet (please help) [Re: charger440sixpak] #744250
07/09/10 10:38 PM
07/09/10 10:38 PM
MI
MI
Would that be one wide stripe or two thin ones?
Roman Sobilo
Re: correct tires by decoding buildsheet (please help) [Re: AfterHoursResto] #744251
07/10/10 10:26 AM
07/10/10 10:26 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
single white stripe dan
Re: correct tires by decoding buildsheet (please help) [Re: ph23vo] #744252
07/13/10 03:34 AM
07/13/10 03:34 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Goodyear Polyglas E70-14 "white stripe" (SINGLE)
