I've seen a few posts here that Magnum motors respond really well to being carb'd and put in older platforms so I thought I might ask for some opinions on replacing the EFI on my 92 Dak with a carb, RPM intake and MSD.
It's a 92 Dak RC shorbed 3400 lbs. 5.2L A518 3.55 open.120K on the clock and runs great.
The only Mods are a K&N filter and Flomaster muffler.It's lowered 2 in the front and 4 in the rear with R/T wheels.
It went 15.0 @ 90 with a 2.19 60ft with obvious tire spin. It has 275/60/17 rear tires that measure out to 30". I only used 1st and 2nd and hit the rev limiter (5200RPM) about a lenght before the traps.
I have since hung a 3.92 LSD in it and it runs MUCH better but I have not got an ET since.
How much do you guys think it might pick up if any?
![](/ubbthreads/images/graemlins/shruggy.gif)
