I have a set 2531110m hemi heads on the 472. I've read discussions on valve seat fitment and valve guide issues, but I'm curious about the porosity issues. What exactly is the issue? Symptoms? Identifying, Consequences? Tests? Remedies?
I have no issues with oil in coolant, coolant in oil, compression, oil pressure and coolant pressure but I am alot neurotic and a little OCD and would like some feedback on the issues associated with porosity.
Also is there a list of Mopar performance casting #s, casting dates associated with the quality control problems
Glenn C
