Re: How much can I adjust the torsion bars before alignment
[Re: DaytonaTurbo]
#743864
07/09/10 08:30 AM
07/09/10 08:30 AM
Posts: 4,924 new berlin wisconsin
Mr T2U
the absolute correct answer is zero. in the real world with tolerances you can probably adjust about 1/2" before you really start changing the geometry enough to get it out of tolerances. if you have the gauges just change the height and drive the car. if it drives remotely strange break out the gauges and check things out.
perception is 90% of reality
[Re: ToddP]
#743867
07/10/10 09:15 AM
07/10/10 09:15 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Nobody will tell you it's ok because it will change the alignment but here's some thoughts for you. I would get an alignment after an extreme change but a bit is not worth worrying about.
If you already have a close to perfect alignment and adjust your height some. It will affect both sides and it will affect them the same.
So now you may have a bit of caster change and again maybe even a slight camber change.
Having both sides the same is more important to than actually having the numbers dead on because there are many pros and cons to more or less caster or more or less negative camber.
Then just check the toe before and after.
I've adjusted the ride height many times without killing the front tires or the way a car drives.
