dealing with a seized engine
#743834
07/09/10 12:37 AM
07/09/10 12:37 AM
Posts: 450 DFW
68RRFlyer
DFW
Hey Guys, I'm considering buying a car that's been sitting a while. It's been garaged and off the road since the 90s, the motor's all intact and complete, but it's locked up from sitting. It's the original motor so I'd like to try and save it. What's the best way to go about doing this? Tear it down to get access to the rings, or should I just keep it together, pull the plugs and fill each cylinder with PB Blaster and let it sit? I've heard people using that, ATF fluid, or diesel fuel, as well. How would you guys go about saving this engine? Thanks! Cheers Dave
Re: dealing with a seized engine
[Re: 68RRFlyer]
#743835
07/09/10 12:46 AM
07/09/10 12:46 AM
Posts: 171 Indy
moparman89
Indy
Its going to have to be rebuilt, so why not take it apart? ATF mixed with Acetone is a wicked solution that will break up anything. Its what I used on all my seized 440's.
School of Automotive Machinists Racing
[Re: DaytonaTurbo]
#743837
07/09/10 01:01 AM
07/09/10 01:01 AM
Posts: 4,848 Memphis
HemiRick
Memphis
If it will break loose, I've seen engines so corroded up, that beating each piston out from the bottom side with a piece of hardwood and sledge was the only way to get them apart.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: 68RRFlyer]
#743840
07/09/10 01:46 PM
07/09/10 01:46 PM
HemiRick
Memphis
If the cylinder walls are so corroded that it wont turn, it wont have any real piston ring seal either and probably wont run due to low compression. At least not on all 8.
[Re: HemiRick]
#743842
07/09/10 02:44 PM
07/09/10 02:44 PM
DaytonaTurbo
Manitoba, Canada
And even if it does run you can do more damage to the bores than good, even just cranking it over with the starter enough can drag enough crud to scratch up the bores more than necessary. I would just break it loose then take the pistons out right away.
