New Carpet #743750
07/08/10 08:24 PM
07/08/10 08:24 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
I know this topic has probably been brought up before, but last fall I put new carpet in my Coronet. Problem is it still is not taking shape to the floor. Is there an adhesive I can spray down first to make it stick?
Re: New Carpet [Re: 493RT] #743751
07/08/10 10:16 PM
07/08/10 10:16 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I lightly applied some contact cement only in problem areas to hold down the carpet.
Re: New Carpet [Re: Paul_B] #743752
07/08/10 11:28 PM
07/08/10 11:28 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
the carpet probably will never fit the floor properly. The only cure that I found and it worked perfectly I may add was to discard the junk carpet that I bought, did I say it was a trim parts carpet, and replace it with a carpet from Motoer Parts South. This carpet fit like a glove right out of the box!!
