Re: Using spacer above K-frame
[Re: Vert]
#74233
06/15/08 10:53 PM
06/15/08 10:53 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I have heard people talk about it on here. I would not see a real problem with it, there should be plenty of alignment adjustment to work with, drive line angle would be another consideration, along with shroud and radiator alignment/tranny lines if an auto.
Careful, your character's showing!
[Re: wings471]
#74236
06/16/08 12:42 AM
06/16/08 12:42 AM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
The only reason I can think of not to do it is that it will change (slightly) the angles/distance between the upper and lower control arms. I doubt it will be a big deal since folks are always swapping out spindles for taller units. Maybe you should do that as well to make things right? ![](/ubbthreads/images/graemlins/laugh2.gif)
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
[Re: Supercuda]
#74240
06/16/08 10:50 PM
06/16/08 10:50 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The front pivot for the torsion bars will move, the rears won't.
![](/ubbthreads/images/graemlins/iagree.gif)
Will it be an issue? I dunno.
No it won't...
[Re: 1_WILD_RT]
#74241
06/16/08 10:55 PM
06/16/08 10:55 PM
all that just for Schuamacher conversion mounts? me thinks its easier to get out the plasma cutter and/or sawzall and mig and just do it yourself. then you can put the engine wherever one wants.
#74243
06/17/08 07:52 AM
06/17/08 07:52 AM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Nahhh. It the mounts AND the Stage V AND the Rallye hood. If I have to, I'll get a solid mount from John Arruzza, or spend more hard-earned money on a Hemi K-frame and mounts. Or I could get really spendy and look at an AlterKation K frame But that seems a bit more costly than 4 1/4 inch thick square washers and an hour of my time.
But you... sound like a guy that like to have fun with the PC and mig. So what suggestions do you have that I can do with tin snips and a soldering iron? I'm short a mig and PC currently. ![](/ubbthreads/images/graemlins/weld.gif)
[Re: Vert]
#74245
06/17/08 06:12 PM
06/17/08 06:12 PM
needlepoint is fun.
#74246
06/17/08 09:31 PM
06/17/08 09:31 PM
Vert
Annapolis, MD, USA
needlepoint is fun.
%#&**# Dang! I've been outed.
[Re: Vert]
#74249
06/17/08 10:53 PM
06/17/08 10:53 PM
needlepoint is fun.
i didn't even know you where in ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Vert]
#74250
07/15/08 10:16 PM
07/15/08 10:16 PM
Vert
Annapolis, MD, USA
Update! I got some EXCELLENT info on this at Carlisle. I stopped by U.S. Car Tool and mentioned my plans to John. He pointed out some specifics to keep in mind.
- There is a recess in the frame on B&E bodies where the k-frame bolts go thru.
- Ma Mopar used special hardened Grade 10 bolts to hold the K-frames in place on B&E bodies.
- They have a "shoulder" which fits in the recess of the frame.
I still plan to do it, since I won't be racing anyway with a vert.
