Page 1 of 3 1 2 3
Gonna build some log manifolds HELP!!!!!!! #742131
07/06/10 07:43 PM
07/06/10 07:43 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
So I am gonna hang a set of snails on my coronet and buy what i have been reading that making a set of nice tube headers are a waste of time.
So I plan on making some logs similar to what HEMIFRED have on his car.
I already have some 1/2" flanges to match my heads.
What size tubes and thickness of pipe should i use?
I was thinkin 2 1/8" onto 3" pipe to my turbo flange.
Engine is a 490ci Indy headed Wedge.
Post deleted by Defbob [Re: RockChip] #742132
07/06/10 08:54 PM
07/06/10 08:54 PM
Re: Gonna build some log manifolds HELP!!!!!!! #742133
07/07/10 02:37 AM
07/07/10 02:37 AM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
Thanks !!!!! that really gonna help, every one thinks I should make some fancy headers but i dont think its that important on a Turbo engine.
Post deleted by Defbob [Re: RockChip] #742134
07/07/10 03:09 AM
07/07/10 03:09 AM
Re: Gonna build some log manifolds HELP!!!!!!! #742135
07/08/10 07:06 PM
07/08/10 07:06 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Durability will be the problem, not power output. You will go crazy repairing cracked/ warped logs. You dont have a symetrical port spaced hemi. Your center ports will give you more grief than most are willing to put up with. Do yourself a favor and listen to what "everyone else" says.
Re: Gonna build some log manifolds HELP!!!!!!! [Re: TRENDZ] #742136
07/08/10 10:16 PM
07/08/10 10:16 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My hot rod is an exhaust leak from hell. I can't keep gaskets in it and have had to repair a few cracks too.
My logs use 1/2" flanges.
- Stu Harmon
Re: Gonna build some log manifolds HELP!!!!!!! [Re: feets] #742137
07/08/10 11:59 PM
07/08/10 11:59 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
I use stock manifolds sealed to the heads with high temp RTV. Never had a leak...
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Gonna build some log manifolds HELP!!!!!!! [Re: CW25] #742138
07/09/10 08:29 AM
07/09/10 08:29 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Make sure both the exh flange side and head side are perfect and don't use a gasket, just some high temp sealer.
Re: Gonna build some log manifolds HELP!!!!!!! [Re: CW25] #742139
07/09/10 09:52 AM
07/09/10 09:52 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's a great way to do it! Unfortunately, I couldn't make it happen without major surgery to the manifold or engine mounts.
- Stu Harmon
Re: Gonna build some log manifolds HELP!!!!!!! [Re: feets] #742140
07/09/10 02:37 PM
07/09/10 02:37 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
Please post pics of your progress . I have also been thinking of doing this!!
www.sikosracing.net Heads up Drag racing
Re: Gonna build some log manifolds HELP!!!!!!! [Re: moparmattkos] #742141
07/09/10 04:40 PM
07/09/10 04:40 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I haven't done anything about it.
- Stu Harmon
Re: Gonna build some log manifolds HELP!!!!!!! [Re: feets] #742142
07/10/10 07:19 AM
07/10/10 07:19 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Copper is your friend....
Re: Gonna build some log manifolds HELP!!!!!!! [Re: CokeBottleKid] #742143
07/10/10 07:54 AM
07/10/10 07:54 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Copper gaskets blow out too.
I have the ability to create an exhaust leak after the first sustained boost run.
Yeah, the logs are warped.
- Stu Harmon
Re: Gonna build some log manifolds HELP!!!!!!! [Re: feets] #742144
07/10/10 11:44 PM
07/10/10 11:44 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Now that the logs are well seasoned, just take them to a machinist that knows what he is doing and have the flanges trued. Problem solved. My machinist does this with big block Chev motorhome manifolds all the time. They are famous for warping but once seasoned and trued are good to go.
Kevin
Re: Gonna build some log manifolds HELP!!!!!!! [Re: Twostick] #742145
07/11/10 11:15 AM
07/11/10 11:15 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
They are "seasoned" enough that cracks are popping up here and there.
- Stu Harmon
Re: Gonna build some log manifolds HELP!!!!!!! [Re: feets] #742146
07/11/10 12:16 PM
07/11/10 12:16 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Disimilar metals?
Re: Gonna build some log manifolds HELP!!!!!!! [Re: Duner] #742147
07/11/10 12:51 PM
07/11/10 12:51 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Disimilar metals?
Probably weak welds or too thin a metal. Gotta build them beefy.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Gonna build some log manifolds HELP!!!!!!! [Re: DusterDave] #742148
07/11/10 02:16 PM
07/11/10 02:16 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Bingo! Metal was too thin. I should have used weld els.
- Stu Harmon
Re: Gonna build some log manifolds HELP!!!!!!! [Re: feets] #742149
07/11/10 08:08 PM
07/11/10 08:08 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
No. They will continue to shrink and harden no matter how used, or how thick they are. You plain and simply need room for expansion and contraction. If you build them so strong that they wont move, you end up first breaking studs. Then, after putting in larger studs, you eventually crack the head. If you make logs and expect them to last you MUST put slip joints in between the ports.
Re: Gonna build some log manifolds HELP!!!!!!! [Re: TRENDZ] #742150
07/12/10 11:46 AM
07/12/10 11:46 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I built the flanges with oversized stud holes with that in mind.
In the past, I cut the flanges between the center and outboard ports. It didn't seem to help that much since the headers were already trashed.
My current flanges are not cut.
- Stu Harmon
Page 1 of 3 1 2 3
