back spacing 68 charger #742039
07/06/10 04:32 PM
07/06/10 04:32 PM
PENNSYLVANIA
GARAGEMAN Offline OP
PENNSYLVANIA
Does anyone know the rear back spacing on a 1968 dodge charger.and the biggest tire I can get under without a rub Thanks
Re: back spacing 68 charger [Re: GARAGEMAN] #742040
07/06/10 08:24 PM
07/06/10 08:24 PM
Chicagoland
chargerron69 Offline
Chicagoland
i had a 15x8 prostar 4.5 bs with 29.5 10.5 with no problems on 69 charger. hope it helps
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: back spacing 68 charger [Re: GARAGEMAN] #742041
07/07/10 09:16 AM
07/07/10 09:16 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Re: back spacing 68 charger [Re: GARAGEMAN] #742042
07/07/10 09:38 AM
07/07/10 09:38 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think you can get away w/ at least a 5" backspace. You can get a ton of tire under these cars w/o tubbing or jacking them up.
Coming soon!!!!
Re: back spacing 68 charger [Re: GARAGEMAN] #742043
07/07/10 09:44 AM
07/07/10 09:44 AM
chicago il usa
K
komninon Offline
komninon  Offline
K
chicago il usa
i have 15x10 with 5 backspace 295-50-15 tires on my 68 charger.fits perfect.you can even go 325-50-15.
Re: back spacing 68 charger [Re: komninon] #742044
07/07/10 11:30 PM
07/07/10 11:30 PM
Richmond, TX
Sinister68 Offline
Sinister68  Offline
Richmond, TX
I've got 17 x 10's with a 5 inch backspace. The tires are 295/45R17's. The tires appear to clear with nearly an inch on the inside and outside of the tire.
-James 2013 Challenger SRT 1968 Charger R/T
Re: back spacing 68 charger [Re: Sinister68] #742045
07/08/10 12:01 AM
07/08/10 12:01 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I used to run a 16x8" wheel with 4.5" bs with a 295/50 tire on my 68 charger. fit perfect. I can send you pics, I took some closeups to show clearance to leafsprings/wheel lips. now I run 18x9.5 with 5.5" backspace. it's a hair more to the "inside" than I like. If I could have afforded custom wheels, I'd have gone 10" wide with 5" backspace.
