I have new motor to put between the rails in a couple weeks
the car is a 78 f body
3350 with driver
727 with a t/a converter 8 inch about 3800 to 4200 stall
out back is a 8.75 with 35 spline spool and axles 3.91 gear. I have 2 tires I run 295/65 drag radial or a 275/60 drag radial
The new motor is a 416 muscle motors kit Eagle crank H beam rods forged flat top pistons should be about 10.1. I have a ported set of eddy heads with a 2.05 intake 160 Exhaust, M1 intake bigs 750 stage 5 carb 1 3/4 headers 3 inch x pipe super 40 flowmasters
Cam is a solid 597 intake 607 exhaust
@.050 259 intake 263 exhaust
I have a plate system on the car also but that's another story
thanks
