Re: why would one side blink but not the other
[Re: Andrewh]
#741175
07/05/10 11:44 PM
07/05/10 11:44 PM
Posts: 9,316 SoCal
68HemiB
SoCal
Indeed, reduced load on one side (one or more bulbs burnt out) can cause that side not to blink.
To split hairs, what is going on is too little load. The turn signal flasher is merely a low-capacity circuit breaker that heats up from the load and opens the circuit. Once open, it cools down, and closes once again. This is what causes the blinking off and on. Without enough load to heat it up enough, it never opens heats up and opens in the first place.
Down to just a blue car now.
[Re: Andrewh]
#741177
07/06/10 11:08 AM
07/06/10 11:08 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Check the front too. I know how your luck works.
[Re: feets]
#741178
07/06/10 11:15 AM
07/06/10 11:15 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Check you didnt put the bulb in backwards also.Its easy to do.Rocky
Chrysler Firepower
