It again depends on how much time you spend driving in gear below the stall rpm.
If you drive for 20 or 30 minutes below 5000 rpm, you will still generate a whole lot of heat. If you drive for only 2 or 3 minutes below 5000 rpm, things will be much cooler. In reality, I'd think with 5000 rpm stall, you are going to have little, if any street use, only good for racing.
![](/ubbthreads/images/graemlins/Twocents.gif)
And if you are racing only, you may want to post this issue over on Unlawful's race section, they probably have more experience to help you there.
