Small block front engine mounting plate. #740530
07/04/10 09:06 PM
07/04/10 09:06 PM
wv
dakster Offline OP
dakster  Offline OP
wv
Anyone have any pictures of a small block engine plate in an A-body, Duster, Demon, Darts?
What kind did you use, is there any out there that are pre fit to go into an A-body with minimal trimming?
Can you use a factory alternator and how would it mount?
Pictures and links to vendors that sell them would be appreciated.
Re: Small block front engine mounting plate. [Re: dakster] #740531
07/04/10 10:54 PM
07/04/10 10:54 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
70 Dart S&W motor plate (Check it before using as mine was cut mirror image, Right side to short. I modified mount to accomodate) Alternator mounted to bottom of plate using brackets and hardware I had laying around.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Small block front engine mounting plate. [Re: DragDart360] #740532
07/04/10 11:45 PM
07/04/10 11:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The right side is suppose to be shorter due to the
engine setting to the right... I've used 3 S&W SB
plates and liked them.... some cutting will be needed
I make all my own now days out of 3/8" plate
Re: Small block front engine mounting plate. [Re: dakster] #740533
07/05/10 12:00 AM
07/05/10 12:00 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
I made mine and was able to keep alt in factory location.
This is a first attempt that I didnt use. I made a few subtle changes to it, but its basically the same. Obviously the little cutout or halfmoon is where the alt goes. It worked sweet for the 6 years I had it on there.
Re: Small block front engine mounting plate. [Re: MR_P_BODY] #740534
07/05/10 05:03 AM
07/05/10 05:03 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
Had mine made by a member here (NHRAMark)
Re: Small block front engine mounting plate. [Re: dc426] #740535
07/05/10 07:48 AM
07/05/10 07:48 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Brian Smith made mine. (408strokerdart) 3/8" thick and drilled for
a STAR vaccuum pump and tank.
Re: Small block front engine mounting plate. [Re: dc426] #740536
07/05/10 09:04 AM
07/05/10 09:04 AM
I like the cut pentastar Might add that to mine next time the engine is out
Re: Small block front engine mounting plate. #740537
07/05/10 11:18 AM
07/05/10 11:18 AM
wv
dakster Offline OP
dakster  Offline OP
wv
Thanks for the pictures everybody.
Strokerpost that's exactly what I was wanting to see.
I'll check around and see if these guys are still making the plates. They all look nice and sturdy.
