Re: Rebuilding heater/defroster unit of a Challenger
[Re: Swiss_Robert]
#740181
08/03/10 07:35 PM
08/03/10 07:35 PM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
Now both halfs are ready. Front half has the core attached with 4 screws - sealed with caulk. Temperature door is lied into it's groove. Rear half needs also some caulk.
To put the halfes together was the most difficult step. Slide in the air-vent door in its hole and keep everything on its place... needs some ingeniousness and patience.
After all these years having a 440 I realized that this means having an attitude... and a budget.
[Re: Swiss_Robert]
#740182
08/03/10 07:41 PM
08/03/10 07:41 PM
Swiss_Robert
Switzerland, Europe
So here it is - back in live. To attach the thick D-shaped gasket on the top it takes some weatherstripe glue. And now is a good time to test the fan and the resistor - if it runs in 2 speeds. On this pic I forgot to attach the ground wire of the fan to the metal backside plate...but I remembered later.
[Re: Swiss_Robert]
#740183
08/03/10 07:44 PM
08/03/10 07:44 PM
Swiss_Robert
Switzerland, Europe
I didn't had this hook in the car - it was missing. I found in the shop manual, how it works and bent a stud to do the job.
[Re: Swiss_Robert]
#740184
08/03/10 07:48 PM
08/03/10 07:48 PM
Swiss_Robert
Switzerland, Europe
Welcome back. Since the blower motor is grounded via the metal plate on the backside of the unit, it's important to make sure that at least one of the three nuts that fix it to the firewall allows electrical contact (just in case you painted the firewall in the meantime - as I did).
[Re: Swiss_Robert]
#740185
08/03/10 07:54 PM
08/03/10 07:54 PM
Swiss_Robert
Switzerland, Europe
When testing with the upper ducts in place I found that "the gap" causes quite some air to be blown under the dash...
I assume that the upper ducts may have warped a little (or were assembled without care 40 years ago). Just in front this part is to close to the heaterbox, on both sides it's okay and no air goes the wrong way.
Since I don't like the idea to heat the inside of the dash, I fixed a stripe of alu sheetmetal.
[Re: Swiss_Robert]
#740187
03/07/13 04:36 AM
03/07/13 04:36 AM
Posts: 401 California, USA
filmsurgeon
California, USA
Thank you for your entire post on your heater box rebuild. I am about to do the same for my '70 Challenger, and will be ordering both the firewall gasket set and heater box restoration kit from DMT. Sadly, I am also missing the hook that is shown in the picture. Unfortunately, I don't have a shop manual to reference, and need to know more specifics on the size, length, and how it works, etc. Can someone help? Thanks.
[Re: 71TA]
#740191
03/13/13 01:39 AM
03/13/13 01:39 AM
filmsurgeon
California, USA
I might see if I can have these hooks made. Sure it wouldn't be a huge seller but would compliment my product line.
That would be great James. I just ordered (from you today) your Heater Box Rebuild Kit and Firewall Gasket Set. These original hooks are being sold on ebay for anywhere between $20.00 to $90.00. The ebay seller has sold everyone he has listed (at least three that I'm aware of). So obviously, they are still in high demand. BTW - the photo I attached of the "original" J-hook was copied from one of his ebay listings. Right now, I am looking for the hook and bolt. Thanks, Joe
[Re: filmsurgeon]
#740192
03/13/13 04:18 AM
03/13/13 04:18 AM
Swiss_Robert
Switzerland, Europe
I would have bought it, if it were available! I can remember that it was quite a pain to get this hook attaching to the cowl. Mine was straight (I didn't know better) but that corner in it will help a lot. Anyway - my car is still not back on the road To many cool things to do - including too many other things to do at that car to make it a bit more perfect. Well, the engine runs, it has brakes and exhaust, even a carpet is in. May be adding wheels, including steering wheel and seats would make it more to be nearly finished...
