94 ram no overdrive #739529
07/03/10 05:09 PM
07/03/10 05:09 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
code reader says code 37 trans temp sensor volts high. where is this sensor located?
Re: 94 ram no overdrive [Re: crowbait] #739530
07/03/10 06:06 PM
07/03/10 06:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On a '94 it's located in the front cooler line just as it leaves the transmission.
Re: 94 ram no overdrive [Re: John_Kunkel] #739531
07/03/10 09:45 PM
07/03/10 09:45 PM
ky.
K
kenworth_goose Offline
K
ky.
Put a new speed sensor in it. The output in the tail of the trans. or transfer case.
Re: 94 ram no overdrive [Re: kenworth_goose] #739532
07/04/10 03:20 PM
07/04/10 03:20 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
John
there is nothing on the line.
This is a 3500 if that makes a difference.
Re: 94 ram no overdrive [Re: crowbait] #739533
07/04/10 05:17 PM
07/04/10 05:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Gas or diesel?
Re: 94 ram no overdrive [Re: John_Kunkel] #739534
07/05/10 12:25 PM
07/05/10 12:25 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
360 gas
