Fuel pressure guage fluctuates when starting up cold #738861
07/02/10 03:44 PM
07/02/10 03:44 PM
CA
66Dodge Offline OP
super gas
66Dodge  Offline OP
super gas
CA
Upon cold start up I can see the needle bounce back and forth between 6 & 7lbs. After freeway driving for 45mins. to bring the engine up to running temperature, I pull over to check and find the needle is now steady at 6 lbs.
Any explanation for this ?
This is on a 383ci. with Holley 750cfm., stock Carter fuel pump.
Re: Fuel pressure guage fluctuates when starting up cold [Re: 66Dodge] #738862
07/02/10 11:40 PM
07/02/10 11:40 PM
at large
moparphillie Offline
at large
If the gauge is liquid filled and the outside temperature is hot and muggy... that is your answer. Heat and humidity have a drastic effect on liquid filled gauges. This is directly from Autometer's Tech Engineering Dept.
Good luck...
Re: Fuel pressure guage fluctuates when starting up cold [Re: moparphillie] #738863
07/03/10 12:28 AM
07/03/10 12:28 AM
CA
66Dodge Offline OP
super gas
66Dodge  Offline OP
super gas
CA
Guage is not liquid filled and tried a different one and same thing happens. Outside temperature was a cool, dry, 60degF. at 9am.
You think it has anything to do with the fuel pump being cold upon initial startup ?
Re: Fuel pressure guage fluctuates when starting up cold [Re: 66Dodge] #738864
07/03/10 01:42 AM
07/03/10 01:42 AM
either the supply (pump) end or the demand (needle/seat) end and I'd say the pump. yes might heat it up real good/thoroughly ahead of time (not sure the best way) & see if that smoothes it out
