Drilling Secondary Plate on Holley 1850 4 bbl
#738199
07/01/10 07:26 PM
07/01/10 07:26 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
Has anyone experimented with drilling the holes in the secondary plate out a tad larger on a 600 cfm Holley 1850 4 bbl? Somewhere, I read about someone trying this, albeit with poor results.
I know about the metering block conversion kit, which I will do, but this questions is more of a curiosity.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Drilling Secondary Plate on Holley 1850 4 bbl
[Re: MoparJ]
#738200
07/01/10 08:15 PM
07/01/10 08:15 PM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
if you have the small "pin" drill bits, it is an easy task. It is a one way path though. Once you get too big,,,,, i would try one bit size at a time. ![](/ubbthreads/images/graemlins/haha.gif)
[Re: MoparJ]
#738202
07/02/10 01:54 AM
07/02/10 01:54 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
What is the reasoning for you to drill the secondary butterflies?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#738203
07/02/10 11:06 AM
07/02/10 11:06 AM
Posts: 7,506 Az
Crizila
Az
I think he is referring to the sec jet plate. There are several company's out there ( Quickfuel for one ) that sell jet plates that accept screw in jets. They are pretty cheap and solve the problem of drilling too big and not being able to back up to a smaller size. They take standard thread holley jets.
Fastest 300
#738205
07/02/10 12:50 PM
07/02/10 12:50 PM
MoparJ
Simi Valley, CA
Yep, that is the exact reason for my question.
For those who know, aren't the plate holes as they are from the factory equivalent to 72 jets?
