yes,I just did this on my 727 I put a manual VB in
did it in the truck
i used a small bottle jack on a block to get it up there
then a large socket the size of the spring cup
jacked it up till it compressed...which is just a little bit
removed the retaining clip and lowerd the jack
removed the cup/spring servo
installed the billet servo/spring/cup,compressed it back up into the hole so I could install the clip in the groove removed jack
I removed the adjuster and the strut bar to swing the lever down out of the way..which I should have placed this as first step just now
took a few trys to get the strut bar back in place but once I got used to looking up at it from the bottom up
i got it sliped back in
that seemd the hardest part for me,but once I figured how to do it i removed it a few times and put it right back every time
not that hard at all
I had thought the servo was gonna compress up further than it did also
but it only moves a 1/8" at most
good luck and might as well adjust the bands up while your at it
good luck
