440-6 center carb problem #737755
06/30/10 11:10 PM
06/30/10 11:10 PM
louisiana
K
kingkt Offline OP
kingkt  Offline OP
K
louisiana
ok so im trying to dial in a 440-6 and the center carb has fuel pouring out the plunger. it takes about a minute before it starts to pour out the top. any of you carb guys think it might be a stuck bowl? or if not any experience with this happening and if so what might be the problem.im hesitant to remove carbs before knowing if theres a solution to the problem without removing them... any and all input is very much appreciated. thank you.
Re: 440-6 center carb problem [Re: kingkt] #737756
07/01/10 12:36 AM
07/01/10 12:36 AM
Washington State
70chall440 Offline
70chall440  Offline
Washington State
sounds like your float is stuck. Tap on it with the big end of a plastic screw driver (not a hammer) and see if that helps. If not, you most like will need to take it off and remove the bowel to see what is going on.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: 440-6 center carb problem [Re: 70chall440] #737757
07/01/10 07:14 AM
07/01/10 07:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said either stuck or set too high.
Coming soon!!!!
Re: 440-6 center carb problem [Re: kingkt] #737758
07/01/10 08:32 AM
07/01/10 08:32 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Replace the o ring on the needle seat assembly & put a little rubber friendly lubricant on the n/s threads when installing.
Re: 440-6 center carb problem [Re: kingkt] #737759
07/01/10 05:52 PM
07/01/10 05:52 PM
Pennsylvania
W
WingedSixBBL Offline
W
Pennsylvania
Mechanical or electric fuel pump fed? I've found the electric pumps usually require a slightly lower float setting vs mechanical
