Re: Magnum Engine Swap ?s
[Re: RED73RALLYE]
#737545
06/30/10 08:10 PM
06/30/10 08:10 PM
Andrewh
Mine is an odd ball thing. It is an experimental harness from painless. They decided not to produce it, but from what I gather, it was basically the jeep 4.0 harness that they added a couple things to. I have a few pics here, but don't want to hijack his post. http://s243.photobucket.com/albums/ff216/andrewshsia/magnum%20swap/
[Re: IMGTX]
#737546
06/30/10 08:24 PM
06/30/10 08:24 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
As for the engine mounts you can use the factory mounts with a few washers on the drivers side so that the engine will stay in the exact same spot.
Just curious, where are these washers supposed to go? I ask becuase I have a 98 magnum block in my demon with stock v8 mounts and no washers...everything lines up fine
[Re: chache876]
#737547
06/30/10 08:38 PM
06/30/10 08:38 PM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
You only need them if you are mixing 318/340/5.2 with 360/5.9 parts. If you use 360 mounts on a 5.9 or 318 mounts on a 5.2 then no spaces are needed.
