Page 2 of 3 1 2 3
Re: 8 3/4 diff markings and ID help.. [Re: OzHemi] #73714
06/16/08 09:23 PM
06/16/08 09:23 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
DUH!?!?!?!?
Careful, your character's showing!
Re: 8 3/4 diff markings and ID help.. [Re: mopar346] #73715
06/16/08 09:30 PM
06/16/08 09:30 PM
Garden Grove, CA
OzHemi Offline OP
Penguin-hating Ginger
OzHemi  Offline OP
Garden Grove, CA
Re: 8 3/4 diff markings and ID help.. [Re: OzHemi] #73716
06/16/08 11:10 PM
06/16/08 11:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A quick search pulled up this... http://shortorderproducts.com/RibType_Pages/rt-ab_RibType_FONTS/rt_ab_RibType_Fonts.html
FWIW I bought three sets from my local print shop back in the 90's, All three sets together were around fifty bucks... I've used them on six cars & I've loaned them to a few friends...
Re: 8 3/4 diff markings and ID help.. [Re: 1_WILD_RT] #73717
06/17/08 07:25 PM
06/17/08 07:25 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Just dropped in and you're right it's a 073... ...No wonder I could'nt find the code when I did a quick search the other day...
Re: 8 3/4 diff markings and ID help.. [Re: screamindriver] #73718
06/17/08 08:56 PM
06/17/08 08:56 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
I thought it might have been my camera there for a bit..
Re: 8 3/4 diff markings and ID help.. [Re: ECS] #73719
06/18/08 01:53 PM
06/18/08 01:53 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
We will be offering the original type stamps by the end of the summer. They will incorporate the exact font as the ones used by the factory. Here is a sample of what was in my Challenger and the stamps I made that matched exactly what was originally there.
Re: 8 3/4 diff markings and ID help.. [Re: ECS] #73720
06/18/08 02:42 PM
06/18/08 02:42 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
Any thoughts on what these codes mean on mine?
Re: 8 3/4 diff markings and ID help.. [Re: OzHemi] #73721
06/18/08 06:14 PM
06/18/08 06:14 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
On the other side of your third member, under the protruding lip, is there another white stamping of some kind? If not, that marking may be some type of date code for your particular unit. Keep in mind that there were a couple of variations and changes for the way the date was stamped throughout the year.
Re: 8 3/4 diff markings and ID help.. [Re: ECS] #73722
06/18/08 06:30 PM
06/18/08 06:30 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
Here is the other side..and thanks for the info...interesting to know !
Re: 8 3/4 diff markings and ID help.. [Re: OzHemi] #73723
06/18/08 08:01 PM
06/18/08 08:01 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Your casting is completely different than the one in my car. I have seen the variations but never gave it too much thought. That is the date stamped on the side by the filler hole because that casting did not allow enough room to be stamped on the reinforcing rib underside. Look at my example and you can see the difference. My date of 12/6 is stamped on the underside of the casted rib. I will post 3 different rear end housings (as soon as I take the pictures) to show the contrasting styles that were used. Thanks!
Re: 8 3/4 diff markings and ID help.. [Re: ECS] #73724
06/18/08 08:12 PM
06/18/08 08:12 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Is the three digit yellow number on both side or one side of the housing tube? I cleaned mine and found one but that doesn't mean the other wasn't there (if there was one on the other side).
Here's mine; '68 Charger R/T, 3.23:1 non-suregrip with 11" drums. "242"
Troy
Houston Mopar Connection Club
Re: 8 3/4 diff markings and ID help.. [Re: hemi68charger] #73725
06/18/08 09:01 PM
06/18/08 09:01 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
You are correct. I documented a Challenger T/A that had another yellow stamping on the direct opposite adjacent side of the front date stamping. I would like to find someone who worked at the facility and was part of this stamping procedure. They could help take the guess work out of what we are trying to uncover.
Re: 8 3/4 diff markings and ID help.. [Re: ECS] #73726
06/18/08 10:55 PM
06/18/08 10:55 PM
On OZHEMI`s photo would`nt the date code be the 2189 under the part number?
Re: 8 3/4 diff markings and ID help.. #73727
06/18/08 10:58 PM
06/18/08 10:58 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
Would that go along with this code?
Re: 8 3/4 diff markings and ID help.. #73728
06/18/08 11:17 PM
06/18/08 11:17 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
That is the casting date of the housing unit. The actual assembly date (Gears, pinion, etc...) of the rear end would be what was designated by the white stamping.
Re: 8 3/4 diff markings and ID help.. [Re: ECS] #73729
06/19/08 12:29 AM
06/19/08 12:29 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Another good thread on this subject from the past:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: 8 3/4 diff markings and ID help.. [Re: autoxcuda] #73730
06/19/08 05:51 PM
06/19/08 05:51 PM
People's Republic of Kali
70runner Offline
70runner  Offline
Can you guys indicate a font which is a good approximation of the 3 digit part number on the axle tube?
Re: 8 3/4 diff markings and ID help.. [Re: 70runner] #73731
06/19/08 10:05 PM
06/19/08 10:05 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
I found a couple that were close but not an exact match. I had to take the fonts into an "illustrator" program and convert them into "characters" in order to manipulate and change their appearance. That allowed me to match the exact font and replace what I found on my axle setup.
Re: 8 3/4 diff markings and ID help.. [Re: ECS] #73732
06/19/08 10:38 PM
06/19/08 10:38 PM
11-10 I understand the X I`m not sure the date on the gears is what?
When are you thinking you may have your stamps ready for resale?
Re: 8 3/4 diff markings and ID help.. #73733
06/20/08 01:55 AM
06/20/08 01:55 AM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
The stampings were done to make "sense" for whatever plant or employees needed to understand the rear end breakdown. I am not sure what all of the variations and colors of markings meant. Having the original samples certainly makes it easier to eliminate the guess work when trying to replace them.
I can have stamps made up at anytime. I do not have a set program or pricing as of yet. We just finished the different fonts, so this project is still in the beginning stages.
Page 2 of 3 1 2 3
