H BOLTS #737132
06/30/10 06:52 AM
06/30/10 06:52 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Were the H Bolts black phosphate? Thanks
Re: H BOLTS [Re: 70 buzz] #737133
06/30/10 07:30 AM
06/30/10 07:30 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
H = Hyland bolt Co.( I think I spelled it right)
I'm assuming carb bolts or thermostat bolts, but yes they were dark phosphate
Re: H BOLTS [Re: gtx6970] #737134
06/30/10 09:33 AM
06/30/10 09:33 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
What about the distributor bolt Wasn't that a H bolt also?
Re: H BOLTS [Re: 70 buzz] #737135
06/30/10 09:40 AM
06/30/10 09:40 AM
It's a dry heat
It's a dry heat
Yes, and same plating
