A body spindles difference #737127
06/30/10 06:06 AM
06/30/10 06:06 AM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
Quick question here...what is the difference between 10" drum spindles and disk brake spindles on a 73 and up A body?
Reason I ask is I bought a kit from scarebird and it does not fit the 73 spindles...upper holes match but lowers do not...I have a 72 with 9" drums...but I want the larger bearings and ball joint.
Re: A body spindles difference [Re: friesza] #737128
06/30/10 11:47 AM
06/30/10 11:47 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Both the drum and disc 73-76 A body spindles use the same lower balljoint so if the kit you have doesnt match the lower bj spacing its not for the 73-76 spindles.
Re: A body spindles difference [Re: nomore65BelvJim] #737129
06/30/10 03:22 PM
06/30/10 03:22 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
I guess what I am asking is the drum brake spindles the same as the disk on 73 up A body...I am not worried about the balljoints....and if they are the same where can I get the necessary components for the disk setup?
Re: A body spindles difference [Re: friesza] #737130
06/30/10 03:34 PM
06/30/10 03:34 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
They are not the same spindles. Drum and disk are different.
I have a set of spindles/caliper brackets/shields that will work on you car if it's a 73+ car. Came off an F body car.
Might be interested in the scarebird stuff for a car I'm working on.
Re: A body spindles difference [Re: RobX4406] #737131
06/30/10 04:10 PM
06/30/10 04:10 PM
Sweet Home, Oregon
friesza Offline OP
friesza  Offline OP
Sweet Home, Oregon
Let me know....I am interested in that setup...I am off to work and will not be able to reply till tomorrow.
